[GRASS5] gis.m does not use whole area
Thu Mar 23 08:57:10 EST 2006
Hamish wrote:
> > > can we try a grey & hatched background (black "X" diagonal lines
> > > crossing) to indicate what's NULL and what's out of bounds? Or
> > > alternating block pattern like GIMP uses? Or something like that.
> > > This has been a confusing part of GRASS for a Long long time.
> > That would be nice ... the new graphical interface looks so good, that
> > it is really a bit confusing... Idrisi shows new map always in window,
> > which is resised according to displayed map. In GRASS this could be
> > done for the default region. Would this be sollution?
> I always found the old NVIZ controls jumping around & resizing
> themselves very distracting.
> bonus feature: If checkered blocks are used, make their size as the
> closest power of 10 to the map units. Sort of an undocumented barscale.
> "cute" but useful.
And awkward. If you use a stipple (tile), the repeat frequency is
constrained to be an integral number of pixels.
By far the easiest solution is to just change the canvas' background
from white to light grey.
