[GRASS5] New GIS Manager
Michael Barton michael.barton at asu.edu
Sun Mar 26 10:40:41 EST 2006
Up until a couple weeks ago, I'd say it could probably be installed on 6.0.x
and most of it would work.
With the new, extensive changes to the module gui's, involving a change to
the C module parser.c, I don't know now.
In terms of stability, it is undergoing a rapid set of changes right now and
over the next week +/-. It should calm down after that.
I've got a bunch of things to commit to the cvs on Monday that will fix bugs
in duplicating and compositing, as well as other stuff.
I've managed to integrate most of what I'm doing with the new work by Cedric
Shock on the module GUI. However, I've run into a couple items that have
broken due to the new architecture. The most notable that I haven't been
able too fix yet are interactive querying and measure tools on the map
display toolbar. These should be easily fixable once Cedric is back next
week.
If these don't bother you, I'd recommend trying it after Monday.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Michael Rensing <michael.rensing at shaw.ca>
> Date: Sat, 25 Mar 2006 07:27:53 -0800
> To: "'grass5 at grass.itc.it'" <grass5 at grass.itc.it>
> Subject: [GRASS5] New GIS Manager
> Hello Michael et al.
> I took a quick look at the screenshot of the new GIS Manager you've been
> developing, and it looks impressive.
> Can the new GIS manager be installed on 6.0.2?
> Would you say it's stable enough to use for doing GIS, or is it still
> too early? I don't mind a few crashes and making bug reports, but I'd
> like to get a little map development done in between. ;-)
> Regards,
> Michael
