[GRASS5] problem with v.vol.rst
Stefán István stefi at geohidroterv.hu
Thu Mar 30 01:44:48 EST 2006
Hello List,
I've been routed from the general Grass list to here with my problem.
I have a problem with v.vol.rst module:
If I set the tension parameter to high value (over 40) then after I make
slices from the volume, the resulted 2d raster maps will contain squares.
The author of the r3.to.rast module says that it could be a problem of the
interpolation module. In the attached jpeg you can see what I mean under
"squared".
Thank you for your help,
Istvan
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060330/d0de6cf1/dump.jpg
