[GRASS5] features needed for 6.2
Moritz Lennert mlennert at club.worldonline.be
Thu Mar 30 04:12:22 EST 2006
Radim Blazek wrote:
> On 3/29/06, Glynn Clements <glynn at gclements.plus.com> wrote:
>>Hamish wrote:
>>>Restructuring of the raster elements into a $MAPSET/raster/ dir means a
>>>break to GRASS 7.0. It makes sense that this should happen in
>>>combination with and at the same time as a revamp of the raster format
>>>itself. That way we only have to do the transition once.
>>I disagree. Switching the raster directory layout is much simpler than
>>a new raster format. With the former, it's clear what needs to be
>>done; it's just a matter of doing it.
> Yes, but what benefits can a new dir structure bring to users?
> The GRASS database should always be access through library
> or modules.
This would mean that we need a module which allows the selective
extraction of maps in GRASS format (without going through v.*.ascii).
Moritz
