[GRASS5] Re: $ETC/cleanup fails on directories in .tmp/
Mon May 1 05:52:50 EDT 2006
> a couple of GRASS modules generate subdirectories within the .tmp/
> directory of mapsets. I have discovered that etc/clean_temp fails
> on cleaning those as it is written to remove files only:
http://article.gmane.org/gmane.comp.gis.grass.devel/11560
did this fix ever happen? I'm still seeing orphaned directories in .tmp/
thanks,
Hamish
