[GRASS5] Re: d.rgb: different display in gis.m and d.m
Michael Barton michael.barton at asu.edu
Mon May 1 10:00:32 EDT 2006
Maciek,
I *THINK* you've hit a bug I reported in d.rgb and d.his about a month back.
I'm pretty sure that they treat "0" as NULL. This is probably a holdover
from the old 'pre-NULL' days of GRASS. Does your map use "0"s? If so, try
changing to another value and see what happens.
I don't know why it's showing up in gis.m and not in d.m, but probably has
to do with the x11 vs. PNG/PPM display driver architecture. I'm adding Glynn
to the copy list because he may have some insight into what is going on.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciek Sieczka <werchowyna at epf.pl>
> Date: Mon, 1 May 2006 13:40:29 +0200
> To: <grass5 at grass.itc.it>
> Cc: <michael.barton at asu.edu>, <cedricgrass at shockfamily.net>,
> <hamish_nospam at yahoo.com>
> Subject: d.rgb: different display in gis.m and d.m
> Hi,
> Please see the attched screendumps. Both are the output of 'd.rgb
> red=d.r green=d.g blue=d.b -o' called from gis.m (rgb_tcltk.png) and
> d.m (rgb_mon.png) respectively. Why is the first one different? The
> latter one (rgb_mon.png) seems correct, as r.composite output is
> identical.
> Maciek
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko
> najlepsze z nich!
> http://katalog.panoramainternetu.pl/
