[GRASS5] Re: auto-locate EPSG
Mon May 1 12:36:26 EDT 2006
Markus Neteler wrote:
> > > I tried to add you suggestions bug autoconf gives me bad
> > > news. Apparently I made something wrong.
> > There were some bugs in the macros in my email.
> > > Attached a opatch with your suggestions - may I ask you
> > > to try it (at least autoconf-2.13) and then submit?
> > > Hamish is elected beta tester for Debian :-)
> > I've committed the changes. Everything appears to work insofar as the
> > specified directory gets passed to the projshare.sed script.
> Glynn,
> I have tested it, but it seems to fail:
> checking for location of External PROJ.4 data files...
> checking for /epsg... no
> configure: warning: *** Unable to locate PROJ data files.
> checking for nad2bin... /usr/local/bin/nad2bin
> I have things in /usr/local/... and usually do not use any
> parameters for proj.
You need to actually specify:
	--with-proj-share=/usr/local/share
I need to catch the case where the switch is omitted altogether.
