[GRASS5] gis.m: Zoom and region overhaul, bindings
Cedric Shock cedricgrass at shockfamily.net
Wed May 3 21:39:44 EDT 2006
Hey,
I tossed some more changes to mapcanvas.tcl the CVS direction.
I eliminated almost all of the usage of g.region in mapcanvas.tcl. It is now
used for the following:
1. Saving the current region as gism_temp_region before rendering
2. Setting the region to match the zoom before rendering
2. Loading gism_temp_region after rendering to get the current region back
4. Getting zoom boxes from the current region / default region / saved
regions.
There is no longer any need for the mon_* regions (they are no longer made).
The region previous_zoom is no longer used. Previous zooms are now independent
of each other on each display.
The bounds for zooming and panning are stored in a mapcanvas variable
"moitor_zooms" instead of in regions. There is a history of previous zooms.
It is currently set to 7 (arbitrary).
The background changed region affecting rendering bug is gone.
I cleaned up and greatly simplified the bindings for switching trees in the
gis.m main window. Clicking on windows or "alt-tabbing" to them now brings up
their tree in the gis.m main window.
--Cedric
