[GRASS-dev] Re: [GRASS5] Improvements to gis.m map canvas
Thu May 4 21:43:34 EDT 2006
Maciek Sieczka wrote:
> 1. do we need "d.font romans" in each redraw?
The default font is empty. If you don't set a font, any text will be
missing unless something explicitly sets the font.
If this can be shown to be a significant performance issue, the driver
library could be modified so that the font isn't loaded until the
first time it is used.
> 2. when panning/zooming the are always two in a row "d.frame -e" calls;
> necessary?
Not two of them; the second one would be redundant.
