[GRASS-dev] ./configure error
Markus Neteler neteler at itc.it
Tue May 16 04:19:52 EDT 2006
Paolo Cavallini wrote:
>Found it:
>http://www.intevation.de/rt/webrt?serial_num=3918&display=History
>just remove an excess apostrophe from:
>            if test -r /etc/.relid -a "X`uname -n`" = "X`uname -s`" ; then
>                system=MP-RAS-`awk '{print }' /etc/.relid'`
>Please update the cvs.
The CVS *is* updated (for some weeks now) (also GRASS 6.0-CVS).
Apparently your local copy is outdated. If you read at bottom of
you see that I fixed it and closed the report.
Markus
