[GRASS-dev] Updating categories
Radim Blazek radim.blazek at gmail.com
Fri May 19 12:37:34 EDT 2006
On 5/19/06, Roberto Antolin <roberto at geomatica.como.polimi.it> wrote:
> Hello all,
> Just a question: How can I update the category line of a vector map?
> I'm trying with "Vect_rewrite_line()" and the same line_number and
> line_points, and the new line_cats,
> but I don't like this function because I want to keep the same line_number.
> Did you understand me? Any suggestion?
I did not have enough time so Vect_rewrite_line()
is implemented as
  Vect_delet_line()
  Vect_write_line()
and consequently the 'line number' is changed.
You need to implement Vect_rewrite_line() properly
which is not such problem but you must treat carefully
topology update. Please dont use copy-paste
from Vect_delet_line(), Vect_write_line() and move
the topo update to new functions instead.
Radim
> Thank you,
> Roberto Antolin.
> Roberto Antolin Sanchez
> Politecnico di Milano – Polo Regionale di Como
> Via Valleggio, 11 – 22100 Como, Italy
> tel: +39 031 3327533
> email: roberto.antolin at polimi.it
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
