[GRASS-dev] endian & generic library
Michael Barton michael.barton at asu.edu
Sat May 20 19:09:53 EDT 2006
I would like to humbly mention that the issues below are another reason why
GRASS probably needs something like a PSC and process for formalizing such
decisions now. It has grown from a CERL in-house project to an enormous,
exceedingly complex, wonderfully active, and very powerful geospatial
research tool. A year or so ago, before some code clean up, someone
(Hamish?) noted that GRASS is one of the largest open-source projects in
existence with respect to the size of its code base.
These features that make this such a great project and useful software also
make it increasingly complex to self-mangage in an organized way. We all do
an impressive job of it, but a more structured way of coming to design
decisions would be helpful and will become increasingly important if the
project continues to grow and be dynamic. Maybe we need a fairly loose and
heterarchical kind of organization, but some kind of more formal process
would be helpful to me at least.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Brad Douglas <rez at touchofmadness.com>
> Reply-To: <rez at touchofmadness.com>
> Date: Sat, 20 May 2006 15:02:41 -0700
> To: Hamish <hamish_nospam at yahoo.com>, Glynn Clements
> <glynn at gclements.plus.com>
> Cc: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] endian & generic library
>> Brad:
>>> I believe GRASS should have a similar document that is a bit more
>>> expansive and covering design decisions that affect coding style.  I
>>> think it would cut down on repeat questions.
>> Can you provide some examples of "design decisions"? Just curious.
> Decisions made in the past that the majority of us who haven't been here
> for the long-haul understand.  Few things have been formalized and there
> probably was no reason to do so early on, but GRASS has grown to such a
> size that warrants formalization to some extent, IMHO.
> Examples?  A weak example is the decision to determine endianess at run
> time.  Or the decision to use lib/gis as a repository for functions
> common to other libraries (memory allocation, etc.), then some of those
> libraries not using lib/gis account of "bloat".
> If some of these things sound trivial, it's probably because I take a
> very user-centric approach.  I try to gear things to make the user
> experience better/easier, perhaps to a fault at times.
> Does this help explain my stance a bit better?
> Brad Douglas <rez touchofmadness com>                      KB8UYR
> Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
