[GRASS-dev] v.digit: Qt or wxWidgets
Trevor Wiens twiens at interbaun.com
Mon May 22 16:00:16 EDT 2006
On Mon, 22 May 2006 10:07:36 +0100
Glynn Clements <glynn at gclements.plus.com> wrote:
> Trevor Wiens wrote:
> > This still raises the question of toolkits and this is, even more than
> > language, is a question of preference. wxPython is built on GTK, which
> > begs the question why not just use PyGTK.
> wxPython is based upon wxWidgets, which provides a common interface to
> several GUI toolkits (as well as providing a complete toolkit using
> just Xlib). The most popular version of wxWidgets on Unix/X11 systems
> is wxGTK, although you can also use the Motif or Xlib versions (or, if
> you really wanted to, you could probably use wxMSW atop WINElib).
Oh, I didn't realize that. Interesting. Thanks.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
