[GRASS-dev] Raster format and dual function module
Thu May 25 08:38:17 EDT 2006
> For the time being, it would be better to see if we can improve the
> situation with some minor changes to a few key areas. It would help if
> someone has the time to build GRASS with profiling support and
> actually profile some common usage patterns.
You don't need to build with any special profiling support to try, (!)
Run from valgrind, save interim results to a file using the callgrind
plugin, then visualize that file with KCachegrind.
see  http://kcachegrind.sourceforge.net/cgi-bin/show.cgi
Hamish
