[GRASS-dev] Memory freeing errors in NVIZ (bug 4246)
    Cedric Shock
    cedricgrass at shockfamily.net
    Thu May 25 14:00:33 EDT 2006
Hamish,
I just fixed your keyframe bug in CVS. I didn't close the bug because it
mentions other pieces of the nviz code that do the same thing (something
about draw.c).
Memory allocated by Tcl must be freed using Tcl_Free. This is the same thing
that was the nviz segfault on startup bug. Tcl 8.4 is the first version that
takes advantage of tcl's memory management abstraction, which has been in
place since at least 7.0. Tcl_Alloc and Tcl_Free just happened to be malloc
an free on all platforms before 8.4. I know I've said this before, but it
bears repeating.
To further 8.4ify the nviz code we need to find other places where memory
allocated by Tcl is freed by G_free or glibc free. This isn't a simple task,
and requires someone familiar with the nviz code. I think I got all of the
cases of returning a pointer to free or G_free with an interpreter.
--Cedric
