[GRASS-dev] [bug #4508] (grass) Grass Installation
Request Tracker grass-bugs at intevation.de
Fri May 26 00:14:12 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4508
Subject: Grass Installation
   Thanks for reply.
   I configure Grass as follows :-
   ./configure --prefix=/usr/local/grass6
--with-postgres-includes=/usr/local/pgsql/include/
--with-postgres-libs=/usr/local/pgsql/lib--with-fftw-includes=/usr/local/fftw/include/
--with-fftw-libs=/usr/local/fftw/lib/
   make
After make following error occur :-
Errors in:
/root/Desktop/grass-6.1.cvs_src_snapshot_2006_05_20/raster/r.in.gdal
Then i try,
cd
/root/Desktop/grass6.1.cvs_src_snapshot_2006_06_20/raster/r.in.gdal
make
Then following error occurs:-
main.c: In function `main':
main.c:163: error: `GDAL_DCAP_CREATE' undeclared
(first use in this function)
main.c:163: error: (Each undeclared identifier is
reported only once
main.c:163: error: for each function it appears in.)
main.c:163: error: too many arguments to function
`GDALGetMetadataItem'
main.c:165: error: `GDAL_DCAP_CREATECOPY' undeclared
main.c:165: error: too many arguments to function
make: *** [OBJ.i686-pc-linux-gnu/main.o] Error 1
Even i try for Grass6.0same error occurs
Plz Resolve it on high priroty
-------------------------------------------- Managed by Request Tracker
