[GRASS-dev] nviz colored vectors
Tue May 30 09:12:17 EDT 2006
Hamish wrote:
> > Here is colored vector patch for nviz. It uses grassrgb attribute to
> > get line colors. Displaying of line vectors should work, area vectors
> > aren't implemented.
> Hi Radek,
> thanks for the patch, can you please re-send it as a "unidiff"?
> cvs diff -u grass6/lib/ogsf/
Better still, add "diff -u" to your ~/.cvsrc file.
Nobody uses diff's default output format; most people use either the
context (-c) or unified (-u) formats.
