[GRASS-dev] random colors in d.vect
Martin Landa landa.martin at gmail.com
Wed May 31 05:36:10 EDT 2006
Hi all,
I have tried to implement *random* colouring based on category number
(according to layer number can be implemented later before CVS
committing...), see the attached patch.
I do not completely understand why you need to use in level 2
Vect_line_alive() + Vect_read_line() in contrast with level 1 and
function Vect_read_next_line (). In any case the functions
Vect_read_line () and Vect_read_next_line behave in the same way -
they may return 'line number', -1 or -2. So I do not know why
variable 'ltype' is tested only (switch (ltype)) in level 1.
Best regards, Martin
PS: Temporarily I have no GNU/Linux PC with Internet connection, so
this patch is against CVS snapshot from 2006/05/27.
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060531/f2b5e5ed/d_vect_random_cols-2006-05-31.diff.gz
