[GRASS-dev] NVIZ problem on Intel Macs
Wed May 31 17:44:12 EDT 2006
Michael Barton wrote:
> Lorenzo Moretti is reporting that NVIZ locks up when it tries to start on
> the new Intel Macs. The error is listed below. Anyone have a suggestion? Has
> anyone else had a problem? Should this go to the bug list? We do want to run
> GRASS on the new Macs
> >> X Error of failed request: BadRequest (invalid request code or no such
> >> operation)
> >>   Major opcode of failed request: 129 (Apple-DRI)
> >>   Minor opcode of failed request: 1 ()
> >>   Serial number of failed request: 192
This indicates the OpenGL library isn't compatible with the X server.
There isn't anything which we can do to fix this, although adding the
"-indirect" switch to the "togl" commands in nviz2.2_script might
eliminate the error at the expense of performance (indirect rendering
doesn't use hardware acceleration on the stock X.org servers).
