[GRASS-dev] r.resamp.stats method=sum artifacts
Wed Nov 1 23:26:00 EST 2006
Hamish wrote:
> I've added r.resamp.stats and r.resamp.interp to the GUI menus.
> (Raster->Devel)
> should r.resample be tagged for future removal? (same result as with:
> 'r.resamp.interp method=nearest' ???).
No.
r.resample uses libgis' built-in resampling, so it is guaranteed to
resample in an identical manner to other commands.
"r.resamp.interp method=nearest" performs the resampling itself, so it
could produce slightly different results due to rounding errors. The
method=nearest option was only included for completeness; if you want
nearest-neighbour resampling, r.resample is preferred.
