[GRASS-dev] Re: windows binaries
Moritz Lennert mlennert at club.worldonline.be
Wed Nov 8 11:26:31 EST 2006
Michael Barton wrote:
> Moritz,
> I looked at the script and you are indeed correct. I guess I'd forgotten
> about this. Why is the PNG driver not available in wingrass when immediate
> rendering works (AFAIK using the same underlying driver code and the PNG
> driver)?
Direct rendering does not use the PNG monitor driver which uses UNIX
sockets, but renders directly. AFAIU, in MS Windows we don't have the
UNIX sockets that the monitors depend on.
> I could rewrite d.vect.thematic as a TclTk module, but am reluctant
> to do so because it would make it unavailable to people not using the TclTk
> GUI--and make it more work to port to a new GUI platform.
I agree.
> I very much appreciate your efforts to start a C version. I won't be able to
> advise you on coding, but might be able to offer some more general advice.
Thanks.
Moritz
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Moritz Lennert <mlennert at club.worldonline.be>
>> Date: Wed, 08 Nov 2006 16:05:14 +0100
>> To: Michael Barton <michael.barton at asu.edu>
>> Cc: Hamish <hamish_nospam at yahoo.com>, Paul Kelly
>> <paul-grass at stjohnspoint.co.uk>, <grass-dev at grass.itc.it>
>> Subject: Re: [GRASS-dev] Re: windows binaries
>>> Disclaimer: I only see a fragment of the entire post, and might
>>> misunderstand.
>>> D.vect.thematic does not require any particular driver. It uses d.vect
>>> (iterated over different theme values) to render the final map.
>>> This is why it can work with either an xmonitor or a TclTk canvas (the
>>> latter via the PNG driver and immediate rendering mode.)
>> It won't work in immediate rendering mode since, as you say, it calls
>> d.vect several times and in immediate rendering mode each call creates a
>> new map from scratch, thus losing the overlaying of the different
>> classes. This is why, in order to make it work with gis.m, it is (as far
>> as I know) the only module using the PNG driver, and not immediate
>> rendering. However, the PNG driver is not available in wingrass.
>>> D.vect.thematic should become a C-module like d.vect.chart. But since I
>>> don't know C I simply wish.
>> It is high on my priority list as it will be a convincing argument for
>> my colleagues if I can present them a nice module for thematic mapping.
>> Up to now, I was thinking neither in terms of ps.map, nor in terms of
>> d.graph, but rather in terms of direct access to rendering. In my
>> current understanding this means finding out how d.vect works in detail
>> and applying that to d.vect.thematic.
>> But maybe using do_poly() and do_color() from d.graph might be another
>> solution, but I will have to look at these in detail to understand.
>> I think I will try to quite quickly draw up a description of what I am
>> aiming for and then ask y'all to advise me at how to do it.
>> Moritz
>>> Michael
>>> Center for Social Dynamics & Complexity
>>> phone: 480-965-6213
>>> fax: 480-965-7671
>>>> From: Hamish <hamish_nospam at yahoo.com>
>>>> Date: Wed, 8 Nov 2006 16:05:19 +1300
>>>> To: Paul Kelly <paul-grass at stjohnspoint.co.uk>
>>>> Cc: <grass-dev at grass.itc.it>
>>>> Paul Kelly wrote:
>>>>> Didn't I read that d.vect.thematic needs the PNG driver to work. Have
>>>>> to  confess that I'm not sure what it does - could it use ps.map?
>>>> d.graph would be an easier path I think.
>>>> Hamish
>>> grass-dev mailing list
>>> http://grass.itc.it/mailman/listinfo/grass-dev
