[GRASS-dev] fixes before 6.2.1 [was: ps.map: scale wrong and no output]
Markus Neteler neteler at itc.it
Fri Nov 17 06:12:46 EST 2006
Maciej Sieczka wrote on 11/16/2006 07:07 PM:
> Hamish wrote:
>> So ps.map is pretty much broken in 6.2.0. Bummer.
>> If we can figure out why NVIZ volumes are broken and fix the following
>> bug, I'd vote for a quick 6.2.1 release.
>> NVIZ volume problem (test with slovakia3d dataset) - sometimes it works
>>  * fails from command line; ok if the volume added within NVIZ (bug #4725)
>>    http://intevation.de/rt/webrt?serial_num=4725
>> It would be nice to fix this one too:
>>    https://intevation.de/rt/webrt?serial_num=5209
> Fixing the gis.m, so that it preserved the aspect ratio for
> single-click zooming in the restricted mode, is also a critical issue.
There are some fixes which didn't make it yet into gis.m of 6.2. There
was offlist communication between Michael, Hamish and me on that
but I completely lost track which change should be submitted there.
Markus
