[GRASS-dev] opt->guisection and opt->label for a better GUI world
Michael Barton michael.barton at asu.edu
Fri Nov 17 10:22:07 EST 2006
THANKS!
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Fri, 17 Nov 2006 20:27:56 +1300
> To: grass5 <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] opt->guisection and opt->label for a better GUI world
> I have updated a few complicated modules to use opt->guisection for nicer
> GUI menus using tabs.
>  d.legend
>  d.vect
>  r.report
>  r.watershed
>  r.sunmask
>  v.buffer
>  v.label
> already done by Cedric:
>  r.in.wms
>  g.region
> to be done:
>  (see below)
> Wierdness-
> order of tabs:
>  the tab containing the first flag determines which tab comes first.
>  the default tab "Options" should always be first.
> tcltk bug:
>  guisections with a space in them cause a tcl error (quoting? list vs string?)
>  e.g. r.watershed, r.sunmask (I've used underscores)
> I also updated parser.c to use opt->label a little more. (if opt->label
> is used, it becomes the option's description, and the opt->description
> text becomes the tooltip.
> Suggestion- opt->description is long established, don't mess with it.
>  change opt->label to opt->tooltip and reverse its meaning.
>  Tooltips are good.
> Suggestion 2- move G_define_module(), G_define_flag(), G_define_option(),
>  and G_define_standard_option() out of parser.c. It's a 2,500 line long
>  monster.
> back to guisection:
> The hierarchical rule of thumb is if it has more than 12 subordinates,
> split it into smaller groups. But it's not a hard rule, e.g. I think
> r.in.xyz is ok in a single tab.
> here are the modules with more than 12 options+flags. I have removed
> the ones already mentioned above.
> cd $GISBASE/docs/html/
> # ($1 -2) is to ignore --q,--v
> grep "<DT><b>" * | cut -f1 -d: | uniq -c | sort -n | \
>   awk '{if($1 -2 > 12) print }' | sed -e 's/\.html$//'
>      15 d.what.vect
>      15 g.remove
>      15 r.flow
>      15 r.terraflow
>      16 d.nviz
>      16 d.text.new
>      16 r.out.vtk
>      16 r.ros
>      16 r3.out.vtk
>      16 v.transform
>      17 d.text.freetype
>      17 r.cost
>      17 v.distance
>      17 v.lrs.create
>      18 r.topmodel
>      19 r.in.bin
>      19 r.le.patch
>      19 r.slope.aspect
>      20 r.stats
>      20 r.walk
>      20 v.in.ogr
>      21 r.resamp.rst
>      21 r.spread
>      21 v.in.ascii
>      21 v.lrs.label
>      23 r.texture
>      24 r.sim.sediment
>      24 r.sun
>      25 r.sim.water
>      26 v.vol.rst
>      28 d.vect.thematic
>      30 v.surf.rst
> maybe someone feels organizational.
> Hamish
