[GRASS-dev] NVIZ now broken?
Paul Kelly paul-grass at stjohnspoint.co.uk
Sat Nov 18 08:39:45 EST 2006
Hello Michael
On Thu, 16 Nov 2006, Michael Barton wrote:
> This is real weird.
I can confirm the same problem as Markus, using ActiveState Tcl 8.4.13 on
Windows. Markus' fix also worked for me. I didn't realise Nviz worked on
native Windows actually until Yann Chemin's message yesterday. This is
rather good. Need to use --with-opengl=windows in the configure script.
> The offending ComboxBox is a BWidgets widget. I used this for the express
> reason of NOT breaking any older TclTk installations. The -label option is
> also in other places such as  the vector panel in the GIS Manager. No one
> has reported a problem there.
> BWidgets is sourced in the nviz startup script that calls the others.
> Here's a thought.
> $GISBASE/etc/nviz2.2/nviz2.2_script has the following statement at line 29..
> package require BWidget
> I'm wondering if you have another, more recent, BWidget installation
> installed (with a ComboBox where -label doesn't work) and some way
> accessible to TclTk without specific sourcing. Try replacing line 29 with
> the following...
> package require -exact BWidget 1.2.1
Tried that change and made no difference.
Paul
> This will force nviz to use the BWidget package that comes with GRASS. This
> package DOES have the -label option and it works.
> I'm going to copy Glynn in case he has some insight.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Markus Neteler <neteler at itc.it>
>> Date: Thu, 16 Nov 2006 18:08:01 +0100
>> To: Bob Covill <bcovill at tekmap.ns.ca>
>> Cc: Michael Barton <michael.barton at asu.edu>, GRASS developers list
>> <grass-dev at grass.itc.it>
>> Subject: Re: [GRASS-dev] NVIZ now broken?
>> Hi Bob,
>> great job! I could see the error now and identify it!
>> The tcl error is:
>> Index: panel_site.tcl
>> RCS file: /grassrepository/grass6/visualization/nviz/scripts/panel_site.tcl,v
>> retrieving revision 2.6
>> diff -u -r2.6 panel_site.tcl
>> --- panel_site.tcl      13 Nov 2006 16:33:33 -0000      2.6
>> +++ panel_site.tcl      16 Nov 2006 17:05:59 -0000
>> @@ -125,7 +125,7 @@
>>                 -command "change_color site $row1.color"]
>>      bind $ptcolor <Expose> "$row1.color configure -bg \[get_curr_sv_color
>> site\]"
>> -    set markertype [ComboBox $row1.marker -label "  marker type " -width 8 \
>> +    set markertype [ComboBox $row1.marker  -width 8 \
>>         -textvariable Nv_(siteshape) -modifycmd change_marker \
>>         -values {"x" "sphere" "diamond" "cube" "box" "gyro" "aster"
>> "histogram"}]
>> -label doesn't work here.
>> Whan I use your proposed changes and above fix, I see NVIZ again...
>> I'll leave it to you/Michael to submit changes.
>> Thanks,
>> Markus
>> On Thu, Nov 16, 2006 at 12:29:59PM -0400, Bob Covill wrote:
>>> Hello,
>>> I have been looking into why nviz fails when loading a volume from the
>>> command line (i.e. nviz vol=precip3d.500z50). This is the bug reported
>>> in
>>> http://intevation.de/rt/webrt?serial_num=4725
>>> It appears that the volume drawmode is not initialized which causes the
>>> GUI to hang when loading the volume panel. The attached patch for
>>> map_obj.c in nviz/src should fix this.
>>> Bob
>>> --- map_obj.c 2006-11-16 12:22:16.000000000 -0400
>>> +++ map_obj.c_bak 2006-11-16 12:21:56.000000000 -0400
>>> @@ -437,6 +437,7 @@
>>>      char const_string[] = "constant";
>>>      char zero_string[] = "0";
>>>      int new_id;
>>> +    int mode;
>>>      int *surf_list, num_surfs, i;
>>>      Nv_clientData *new_data;
>>>      int file_used = 0;
>>> @@ -560,6 +561,7 @@
>>>          return (TCL_ERROR);
>>>      new_id = GVL_new_vol();
>>> +    mode = 0;
>>>      /* See if there is a default file name specified */
>>>      if ((argc >= 3) && (strncmp(argv[2], "name=", 5))) {
>>> @@ -570,6 +572,9 @@
>>>              return (TCL_ERROR);
>>> file_used = 1;
>>> +            mode |= DM_GOURAUD;
>>> +     GVL_isosurf_set_drawmode(new_id, mode);
>>> +            GVL_slice_set_drawmode(new_id, mode);
>>>      sprintf(id, "Nvol%d", new_id);
>>> grass-dev mailing list
>>> http://grass.itc.it/mailman/listinfo/grass-dev
>> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
>> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
>> MPBA - Predictive Models for Biol. & Environ. Data Analysis
>> Via Sommarive, 18        -       38050 Povo (Trento), Italy
