[GRASS-dev] NVIZ now broken?
Markus Neteler neteler at itc.it
Sat Nov 18 16:05:08 EST 2006
Michael,
as far as I see the ComboBox is used in a different way:
mapprint.tcl:    ComboBox $row.c -label "" -width 20  -textvariable psprint::paper_preset \
vector.tcl:    ComboBox $row.b -label [G_msg "label part to align with vector point"] \
vector.tcl:    ComboBox $row.c -label [G_msg " justification"] \
-> note G_msg in vector.tcl
while it was in NVIZ:
set markertype [ComboBox $row1.marker -label "  marker type " -width 8 \
Markus
On Sat, Nov 18, 2006 at 10:40:03AM -0700, Michael Barton wrote:
> Paul,
> Thanks much for the update. This  is easy to fix in nviz. The widget label
> can be provided by a separate label widget instead of using the ComboBox
> -label option.
> However, I'm much more concerned about the larger issue of the version of
> bwidgets that GRASS depends on not working correctly. This same ComboBox
> widget with -label option is used in a number of other places in the GUI
> (such as the GIS Manager vector layer panel).
> If it is failing in one place (nviz) it should be failing in all places if
> this is a general problem. If it is only failing in nviz, there is some
> other more fundamental problem that needs to be solved or I will have no
> idea of what kinds of GUI options work and which do not.
> I just tried the new nviz GUI updates on our FC4 system. I still have to
> find out which version of TclTk it is running, but nviz works
> fine--including the ComboBox with -label option. Given Paul's message, it
> doesn't sound like it is limited to a particular version of TclTk or OS. So
> something else is broken.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
> > Date: Sat, 18 Nov 2006 16:43:27 +0000 (GMT)
> > To: Hamish <hamish_nospam at yahoo.com>
> > Cc: <michael.barton at asu.edu>, <neteler at itc.it>, <bcovill at tekmap.ns.ca>,
> > <grass-dev at grass.itc.it>
> > Subject: Re: [GRASS-dev] NVIZ now broken?
> > On Sun, 19 Nov 2006, Hamish wrote:
> >> Markus:
> >>>>> The tcl error is:
> >>>>> Index: panel_site.tcl
> >>>>> RCS file:
> >>>> /grassrepository/grass6/visualization/nviz/scripts/panel_site.tcl,v >
> >>>> retrieving revision 2.6 > diff -u -r2.6 panel_site.tcl
> >>>>> --- panel_site.tcl      13 Nov 2006 16:33:33 -0000      2.6
> >>>>> +++ panel_site.tcl      16 Nov 2006 17:05:59 -0000
> >>>>> @@ -125,7 +125,7 @@
> >>>>>                 -command "change_color site $row1.color"]
> >>>>>      bind $ptcolor <Expose> "$row1.color configure -bg
> >>>> \[get_curr_sv_color > site\]"
> >>>>> -    set markertype [ComboBox $row1.marker -label "  marker type "
> >>>> -width 8 \ > +    set markertype [ComboBox $row1.marker  -width 8 \
> >>>>>         -textvariable Nv_(siteshape) -modifycmd change_marker \
> >>>>>         -values {"x" "sphere" "diamond" "cube" "box" "gyro" "aster"
> >>>>> "histogram"}]
> >>>>> -label doesn't work here.
> >> dumb guess: what if you strip away the spaces in
> >> to
> >>  -label "marker type"
> >> or
> >>  -label "marker_type"
> > Just tried that with various combinations of spaces and no spaces, with
> > and without quotes. Nothing seems to work apart from deleting the -label
> > parameter entirely...
> > Paul
Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
