v.in.ascii (bug #5209) [was Re: [GRASS-dev] ps.map: scale wrong and no output]
Martin Landa landa.martin at gmail.com
Tue Nov 21 05:24:40 EST 2006
sorry, the diff package does not contain gisdefs.h ... correction attached.
Best regards, Martin
2006/11/21, Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2006/11/21, Hamish <hamish_nospam at yahoo.com>:
> > Martin Landa wrote:
> > > >    https://intevation.de/rt/webrt?serial_num=5209
> > > I have tried to fix this bug (the attached patch). Is it OK? -- then I
> > > will commit it to CVS...
> > re. "column type" text, it is probably not a good idea to mix
> > fprintf(stderr, and G_message(). I can see why you kept the first bit
> > with fprintf (no newline), but the module output will look really weird
> > if called with the --quiet flag as only G_message() part would disappear.
> ou, sorry, ... you are absolutely right...
> > What seems to be needed is a G__message() or G_message_no_newline() or
> > somesuch fn that doesn't terminate with a newline.
> I have tried to modify error.c, there is the new G__message () fn.
> > This could be used for "Percent complete:"+G_percent() as well.
> > Then both msgs get switched on/off together with quiet/verbose.
> > The following looks good to me, but to preserve precision should "%lf"
> > be used instead of "%f", perhaps combined with G_trim_decimal()?
> > Index: vector/v.in.ascii/points.c
> > RCS file: /home/grass/grassrepository/grass6/vector/v.in.ascii/points.c,v
> > retrieving revision 1.21
> > diff -u -r1.21 points.c
> > --- vector/v.in.ascii/points.c  18 Oct 2006 05:09:22 -0000      1.21
> > +++ vector/v.in.ascii/points.c  19 Nov 2006 16:45:25 -0000
> > @@ -368,7 +368,15 @@
> >                 if (strlen(tokens[i]) > 0) {
> >                     if (coltype[i] == DB_C_TYPE_INT ||
> >                         coltype[i] == DB_C_TYPE_DOUBLE) {
> > -                       sprintf(buf2, "%s", tokens[i]);
> > +                       if (G_projection() == PROJECTION_LL &&
> > +                           (i == xcol || i == ycol)) {
> > +                           if (i == xcol)
> > +                               sprintf(buf2, "%f", x);
> > +                           else
> > +                               sprintf(buf2, "%f", y);
> > +                       else
> > +                           sprintf(buf2, "%s", tokens[i]);
> >                     else {
> >                         db_set_string(&val, tokens[i]);
> > thanks,
> > Hamish
> Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061121/0f0b43af/v_in_ascii_LL-3.diff.gz
