[GRASS-dev] gis.m - resolution change not adapted in map display
Michael Barton michael.barton at asu.edu
Mon Nov 27 10:40:47 EST 2006
Otto,
This is exactly how it is supposed to work. Changing the display region does
not automatically change the computational region, and changing the
computational region (via g.region) does not automatically change the
display. These are independent.  Also, each display has its own independent
display region.
If you want the display to match a new computational region, select the
option from the zoom pulldown on the display you want to match (set display
to match current region). If you want the computational region to match any
open display, select the option from the zoom pulldown (set region to match
display).
Hope this helps explain.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Otto Dassau <otto.dassau at gmx.de>
> Date: Mon, 27 Nov 2006 10:18:49 +0100
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] gis.m - resolution change not adapted in map display
> Hi,
> in my grass 6.2 version changing resolution of a map with the gis.m is
> not adapted to the map display. The region is changed (written in the output
> of
> gis.m) but in the map display old values remain.
> do others have the same problem?
> example:
> start working in gis.m:
> - display a map (e.g: geology,spearfish)
> - change region to res=200
> - click on redraw in the mao display
> kind regards,
>   Otto
