[GRASS-dev] [bug #5192] (grass) tclsh error in /grass-6.2.0RC2/etc/gm/gm.tcl
Michael Barton michael.barton at asu.edu
Sun Oct 8 14:25:20 EDT 2006
We use TclTk 8.4.x. You are using 8.5 alpha.
I don't know if this is indeed the problem, but it is the first place I'd
start checking given the error you have.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Sat,  7 Oct 2006 17:19:36 +0200 (CEST)
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] [bug #5192] (grass) tclsh error in
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5192
> Subject: tclsh error in /grass-6.2.0RC2/etc/gm/gm.tcl
> Platform: GNU/Linux/x86
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> Hello,
> I packaged GRASS 6.2.0RC2 for Pardus -Linux. When I start GRASS, I get this
> error below.
> And tcl version is 8.5_alpha3...
> murat at pardus grass $ grass
> Cleaning up temporary files.....
> Starting GRASS ...
> Welcome to GRASS 6.2.0RC2 (2006)
> GRASS homepage:                          http://grass.itc.it/
> This version running thru:               Bash Shell (/bin/bash)
> Help is available with the command:      g.manual -i
> See the licence terms with:              g.version -c
> If required, restart the graphical user interface with: gis.m &
> When ready to quit enter:                exit
> GRASS 6.2.0RC2 (samples):~/Desktop/grass > Error in startup script: bad
> variable name "coords(1)": upvar won't create a scalar variable that looks
> like an array element
>     while executing
> "global coords($mon)"
>     (procedure "MapCanvas::pointer" line 5)
>     invoked from within
> "MapCanvas::pointer $mon"
>     (procedure "MapCanvas::create" line 226)
>     invoked from within
> "MapCanvas::create"
>     (procedure "Gm::startmon" line 11)
>     invoked from within
> "Gm::startmon"
>     (procedure "Gm::create" line 69)
>     invoked from within
> "Gm::create"
>     (procedure "main" line 30)
>     invoked from within
> "main $argc $argv"
>     (file
> "/var/tmp/pisi/grass-6.2.0_rc2-3/install/opt/grass-6.2.0RC2/etc/gm/gm.tcl"
> line 521)
> -------------------------------------------- Managed by Request Tracker
