This probably has to do with a recent update (not by me) to use generic
system-wide fonts. The TclTk code *was* using a TclTk font as a default, and
lifting a line height value from the font spec (variable lineht). This has
been changed to use the default fonts specified in option.tcl. In general,
this is fine, but I suspect that either those fonts need to specified a bit
differently or the variables in which the default font strings are stored
needs to be declared as global in the thematic.tcl code in the correct
procedure.
I'll look into it, but just discovered that my version of d.vect.thematic is
no longer working because of a "which awk" statement that was added
(when??). This test fails on my Mac, even though I have awk. It looks like
"which" is a csh term, at least on my system, not a bash term. I don't know
at the moment if this is an issue my Mac binary or with the script.
So I'll have to futz with the whole thing to test. If someone else wants to
do some checking too while I'm trying to deal with the awk thing, I suggest
the following. In thematic.tcl, change...
proc GmThematic::create { tree parent } {
variable opt
variable count
variable dup
variable lfile
variable lfilemask
variable optlist
global iconpath
to...
variable opt
variable count
variable dup
variable lfile
variable lfilemask
variable optlist
global iconpath
global introfont
global bolddefault
global default
...and see what happens.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Thu, 12 Oct 2006 15:59:49 +0200 (CEST)
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] [bug #5204] (grass) grass6.3 - gis.m: can't read
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5204
> Subject: grass6.3 - gis.m: can't read
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs_head_20061012
> Trying to display a thematic layer in the GIS Manager on any vector map in the
> spearfish location, I get
> can't read "lineht": no such variable
> while executing
> "expr {$lineht * 2}"
> (procedure "GmThematic::tleg_item" line 20)
> invoked from within
> "GmThematic::tleg_item $mon $id"
> (procedure "GmThematic::display" line 73)
> invoked from within
> "GmThematic::display $node $mod"
> ("thematic" arm line 2)
> invoked from within
> "switch $type {
> group {
> GmGroup::display $node $mod
> raster {
> GmRaster::display $node $mod
> labels {
> GmLabels::disp..."
> (procedure "GmTree::display_node" line 7)
> invoked from within
> "GmTree::display_node $n $mod"
> (procedure "GmGroup::display" line 22)
> invoked from within
> "GmGroup::display "root" $mod"
> (procedure "MapCanvas::runprograms" line 63)
> invoked from within
> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
> (procedure "MapCanvas::drawmap" line 38)
> invoked from within
> "MapCanvas::drawmap $mon"
> (procedure "MapCanvas::display_server" line 9)
> invoked from within
> ("after" script)
> Moritz
> -------------------------------------------- Managed by Request Tracker
