[GRASS-user] RE: [GRASS-dev] Can't create locations using EPS G codes
Patton, Eric epatton at nrcan.gc.ca
Fri Oct 13 15:08:36 EDT 2006
Thanks, Paul. g.proj -c creates the location perfectly. I confirmed the proj
paramters from within the new location:
g.proj -p
proj       : stere
a          : 6378137
es         : 0.006694380022900787
lat_0      : 46.5
lon_0      : -66.5
k          : 0.999912
x_0        : 2500000
y_0        : 7500000
towgs84    : 0,0,0,0,0,0,0
no_defs    : defined
unit       : metre
units      : metres
meters     : 1
So that's odd. Anyway, I'll use this as a workaround for the future. Thanks
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: Maciej Sieczka; grass-dev at grass.itc.it
Sent: 10/13/2006 2:00 PM
Subject: Re: [GRASS-user] RE: [GRASS-dev] Can't create locations using EPSG
Hello Eric
On Fri, 13 Oct 2006, Patton, Eric wrote:
> One thing that I just noticed is that my epsg file isn't in the
> location as the default path of /usr/local/share/proj/epsg given in
> Grass startup screen. My epsg is in /usr/share/proj/epsg - but I
> this path to the startup window, so it should just get passed
> Could that make any difference?
This file isn't used for anything unless you select to browse EPSG codes
(which simply displays this file). So should make no difference even if
isn't there.
Does the start-up GUI hide error messages? Can you try it from the
command-line and post what you type and what happens? Try something
g.proj -c location=newloc proj4=+init=epsg:XXXX
