[GRASS-dev] Creating location from values stp problem
    Huidae Cho
    grass4u at gmail.com
    Sat Oct 21 14:30:56 EDT 2006
This problem occurs also with Lat-Long (LL), so I had to create a new
location with "g.proj -c".  When "grass -text" creates a new LL
location, it says that the user needs to run g.setproj to properly use
any projection related modules, but it fails because LL is missing from
proj-parms.table.  This is certainly not a good experience for new
users.
Huidae
On Sat, Oct 21, 2006 at 01:47:10PM +0200, Markus Neteler wrote:
> Hi,
> concerning the State Plane (STP) problem, here the error message:
> g.setproj
> Please specify projection name
> Enter 'list' for the list of available projections
> Hit RETURN to cancel request
> >stp
> ERROR: Projection stp is not specified in the table
> Using a debugger, I found that (the new)
> $GISBASE/etc/proj-parms.table
> is analyzed by get_proj_parms() in lib/proj.c. Since STP
> isn't listed there, it fails with
>         if (!proj_parms)
>             G_fatal_error("Projection %s is not specified in the table", proj_out);
> The parameters to query for STP are
> - geodetic datum (e.g. nad27)
> - State FIPS
> - County FIPS for selected state
> - State Plane 1927 or 1983
> - units (US survey Foot, Int. Foot, meter)
> I don't know how to add that in $GISBASE/etc/proj-parms.table
> nor if and why STP disappeared from GRASS 6.2/6.3.
> The code seems to be in general/g.setproj/get_stp.c .
> It seems that it just exits too early in general/g.setproj/main.c .
> Markus
> On Fri, Oct 20, 2006 at 02:05:23PM -0400, Helena Mitasova wrote:
> > Here is another problem that we have found for starting a new
> > location and it applies
> > to g.setproj and the creation of new location from projection values:
> > > when I enter stp (State Plane) for projection it gives an ERROR
> > >that says that stp is
> > >not specified in the table (although it is listed and it used to
> > >work and in lib/gis/projections it is defined.)
> > Was this removed? It used to ask for datum and FIPS codes. It is one
> > of the most common projections
> > in US so it would be good to put it back. It works in GRASS61 from
> > february
> > Thanks Helena
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Markus Neteler  <neteler itc it>  http://mpa.itc.it/markus/
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
