[GRASS-dev] gis.m patch
Michael Barton michael.barton at asu.edu
Sat Sep 2 16:06:50 EDT 2006
This is GREAT. Thanks very much. I have a couple questions.
1. Is there a binary version of this available for people to try?
2. Do your changes affect how gism runs on any other platform?
3. Could you give me a brief one-liner of what each change to gism is
intended to do so I can find a way to keep this in the code if it does have
issues on other platforms?
4. Does NVIZ work?
Great news (even though I don't use Windows)
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Huidae Cho <grass4u at gmail.com>
> Date: Sat, 2 Sep 2006 01:32:19 -0500
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] gis.m patch
> Hi,
> I've patched gis.m so that it can run on Windows natively with the help
> of direct rendering.  PDCurses lets the user to start in text mode, but
> since there are no monitors available, gis.m is the only option for now.
> http://geni.ath.cx/grass/native_wingrass.png shows gis.m running on
> MS-Windows (not Cygwin).
> Huidae
> GRASS is now configured for:  i686-pc-mingw32
>  Source directory:            /home/song/usr/grass/grass6
>  Build directory:             /home/song/usr/grass/grass6
>  Installation directory:      /usr/local/grass-6.3.cvs
>  Startup script in directory: ${exec_prefix}/bin
>  C compiler:                  gcc -g -O2  -D__W98__
>  C++ compiler:                c++ -g -O2
>  FORTRAN compiler:
>  Building shared libraries:   yes
>  64bit support:               no
>  OpenGL platform:             Windows
>   NVIZ:                       yes
>   BLAS support:               no
>   C++ support:                yes
>   DWG support:                no
>   FFMPEG support:             no
>   FFTW support:               yes
>   FreeType support:           yes
>   GDAL support:               yes
>   GLw support:                no
>   JPEG support:               yes
>   LAPACK support:             no
>   Large File Support (LFS):   no
>   Motif support:              no
>   MySQL support:              no
>   NLS support:                no
>   ODBC support:               no
>   OGR support:                yes
>   OpenGL support:             yes
>   PNG support:                yes
>   PostgreSQL support:         yes
>   Python support:             no
>   Readline support:           yes
>   SQLite support:             yes
>   Tcl/Tk support:             yes
>   TIFF support:               yes
>   X11 support:                yes
> Index: gui/tcltk/gis.m/gm.tcl
> RCS file: /grassrepository/grass6/gui/tcltk/gis.m/gm.tcl,v
> retrieving revision 1.25
> diff -u -r1.25 gm.tcl
> --- gui/tcltk/gis.m/gm.tcl 24 Aug 2006 18:04:57 -0000 1.25
> +++ gui/tcltk/gis.m/gm.tcl 2 Sep 2006 06:00:41 -0000
> @@ -69,6 +69,12 @@
>      set execom "spawn"
> +if {[info exists env(MSYSCON)]} {
> +    set mingw "1"
> +    set mingw "0"
>  #fetch GRASS Version number:
>  set fp [open $env(GISBASE)/etc/VERSIONNUMBER r]
>  set GRASSVERSION [read -nonewline $fp]
> @@ -188,7 +194,13 @@
>  # Determine if an element already exists
>  proc Gm::element_exists {elem name} {
> - set failure [catch {exec [list "|g.findfile" "element=$elem" "file=$name"]
> >& /dev/null}]
> + global mingw
> + if { $mingw == "1" } {
> +  set failure [catch {exec [list "|g.findfile" "element=$elem" "file=$name"]
> >& nul}]
> >& /dev/null}]
> return [expr {! $failure}]
> Index: gui/tcltk/gis.m/gmmenu.tcl
> RCS file: /grassrepository/grass6/gui/tcltk/gis.m/gmmenu.tcl,v
> retrieving revision 1.15
> diff -u -r1.15 gmmenu.tcl
> --- gui/tcltk/gis.m/gmmenu.tcl 20 Jul 2006 17:43:19 -0000 1.15
> +++ gui/tcltk/gis.m/gmmenu.tcl 2 Sep 2006 06:00:41 -0000
> @@ -19,6 +19,7 @@
>  global mon
>  global filename
>  global env
> +global mingw
>  # Put this at the top of the file menu.
>  set GuiMenu::Menu_File_Top [subst  {
> @@ -48,10 +49,20 @@
>  lappend descmenu all
>  lappend descmenu options
>  lappend descmenu $tmenu
> -lappend descmenu [subst {
> - {command {[G_msg "GRASS help"]} {} "g.manual" {} -command { exec g.manual -i
> > /dev/null & } }
> - {command {[G_msg "GIS Manager &help"]} {} {[G_msg "GIS Manager help"]} {}
> -command { exec g.manual gis.m > /dev/null & } }
> - {command {[G_msg "About &GRASS"]} {} {[G_msg "About GRASS"]} {} -command {
> source $env(GISBASE)/etc/gm/grassabout.tcl} }
> - {command {[G_msg "About &System"]} {} {[G_msg "About System"]} {} -command {
> exec $env(GRASS_WISH) $env(GISBASE)/etc/gm/tksys.tcl --tcltk & }}
> +# MinGW
> +if { $mingw == "1" } {
> + lappend descmenu [subst {
> +  {command {[G_msg "GRASS help"]} {} "g.manual" {} -command { exec g.manual
> -i >& nul } }
> +  {command {[G_msg "GIS Manager &help"]} {} {[G_msg "GIS Manager help"]} {}
> -command { exec g.manual gis.m >& nul } }
> +  {command {[G_msg "About &GRASS"]} {} {[G_msg "About GRASS"]} {} -command {
> +  {command {[G_msg "About &System"]} {} {[G_msg "About System"]} {} -command
> { exec $env(GRASS_WISH) $env(GISBASE)/etc/gm/tksys.tcl --tcltk & }}
> -i > /dev/null & } }
> Index: gui/tcltk/gis.m/runandoutput.tcl
> RCS file: /grassrepository/grass6/gui/tcltk/gis.m/runandoutput.tcl,v
> retrieving revision 1.12
> diff -u -r1.12 runandoutput.tcl
> --- gui/tcltk/gis.m/runandoutput.tcl 27 Aug 2006 21:19:26 -0000 1.12
> +++ gui/tcltk/gis.m/runandoutput.tcl 2 Sep 2006 06:00:41 -0000
> @@ -169,11 +169,17 @@
>  proc run {cmd args} {
> + global mingw
> # This and runcmd are being used to run command in the background
> # These used to go to stdout and stderr
> # but we don't want to pollute that console.
> # eval exec -- $cmd $args >@ stdout 2>@ stderr
> - eval [list exec -- $cmd] $args >& /dev/null
> +  eval [list exec -- $cmd] $args >& nul
> +  eval [list exec -- $cmd] $args >& /dev/null
> Index: lib/gtcltk/gronsole.tcl
> RCS file: /grassrepository/grass6/lib/gtcltk/gronsole.tcl,v
> retrieving revision 1.6
> diff -u -r1.6 gronsole.tcl
> --- lib/gtcltk/gronsole.tcl 27 Aug 2006 21:19:26 -0000 1.6
> +++ lib/gtcltk/gronsole.tcl 2 Sep 2006 06:00:43 -0000
> @@ -425,10 +425,16 @@
>  proc Gronsole::execout {path cmd ci execcmd} {
> global env
> + global mingw
> set mark cmdinsert$ci
> # Actually run the program
> - set cmd [concat | $cmd 2>@ stdout]
> +  set cmd [concat | $cmd]
> +  set cmd [concat | $cmd 2>@ stdout]
> set message_env [exec g.gisenv get=GRASS_MESSAGE_FORMAT]
>          set env(GRASS_MESSAGE_FORMAT) gui
> Index: lib/gtcltk/options.tcl
> RCS file: /grassrepository/grass6/lib/gtcltk/options.tcl,v
> retrieving revision 1.7
> diff -u -r1.7 options.tcl
> --- lib/gtcltk/options.tcl 19 May 2006 21:19:16 -0000 1.7
> +++ lib/gtcltk/options.tcl 2 Sep 2006 06:00:43 -0000
> @@ -98,3 +98,9 @@
>  if { $osxaqua == "1"} {
>      set keycontrol "Command"
> +    set mingw "1"
> +} else {
> +    set mingw "0"
