[GRASS-dev] [bug #5098] (grass) gis.m; tcltk error when zooming to map with name which exists in more than one mapset
Michael Barton michael.barton at asu.edu
Mon Sep 4 14:31:59 EDT 2006
Maceij has reported this too.
I'm trying to do a bunch of comprehensive bug fixes (they never seem to end)
to gism. I think I've fixed this one.
I was finally able to reproduce a strange one that he also reported about
zooming when 2 or more map display are visible. Reproducing it on my Mac was
difficult, but fixing this was much harder. But I think I got it.
This has involved changing most of the many global variables floating around
to ones tied to local name spaces, and replacing other variables with arrays
indexed by active display monitor.
I hope to get this committed either tomorrow or Wednesday.
Hopefully, this will make the whole system more robust.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Mon,  4 Sep 2006 18:13:15 +0200 (CEST)
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] [bug #5098] (grass) gis.m; tcltk error when zooming to
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5098
> Subject: gis.m; tcltk error when zooming to map with name which exists in more
> than one mapset
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs_head_20060904
> When there are two maps with the same name in more than one of the accessible
> mapsets, then gis.m throws below tcltk error when I try to "zoom to selected
> map". To reproduce in spearfish, just copy any map from the PERMANENT mapset
> to the user1 mapset using the same name and then display it and zoom to it. If
> I enter @mapsetname (i.e. @user1) after the map name zooming to the map works.
> It is probably just a question of catching the WARNING message and ignoring
> it, or of adding the @mapsetname automatically (default to current mapset if
> not set otherwise).
> BTW, I find the warning message a bit weird: when I display roads from user1 I
> get the message "WARNING: 'vector/roads' was found in more mapsets (also found
> in user1)". In my understanding this should read "... (also found in
> PERMANENT)...
> WARNING: 'vector/roads' was found in more mapsets (also found in user1).
>     while executing
> "close $input"
>     (procedure "MapCanvas::zoom_gregion" line 11)
>     invoked from within
> "MapCanvas::zoom_gregion $mon [list "vect=$map"]"
>     (procedure "MapCanvas::zoom_map" line 48)
>     invoked from within
> "MapCanvas::zoom_map $mon"
>     invoked from within
> ".mapcan(1).mf.topf.tb0.mapzoom.zm invoke active"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel #0 [list $w invoke active]"
>     (procedure "tk::MenuInvoke" line 50)
>     invoked from within
> "tk::MenuInvoke .mapcan(1).mf.topf.tb0.mapzoom.zm 1"
>     (command bound to event)
> Moritz
> -------------------------------------------- Managed by Request Tracker
