[GRASS-dev] Use of non-ANSI features
Tue Sep 5 20:35:26 EDT 2006
Working file: lib/ogsf/gsd_img_tif.c
revision 2.9
date: 2006/09/04 21:07:08;  author: cho;  state: Exp;  lines: +5 -1
typedefs for MinGW
+#ifdef __MINGW32__
+typedef unsigned char u_char;
+typedef unsigned short u_short;
+#endif
In general, gratuitous use of non-ANSI features should be eliminated
altogether, rather than worked around.
