[GRASS-dev] Vector file naming
Moritz Lennert mlennert at club.worldonline.be
Thu Sep 7 11:47:49 EDT 2006
Markus Neteler wrote:
 > Brad Douglas wrote on 09/07/2006 04:46 PM:
 >> Who says the *file name* has to be the same as the table name?  No SQL
 >> spec governs that...it's up to the DBMS.  GRASS just doesn't give me
 >> that option, currently.
 > I think it does: v.db.connect...
Yes, but r.to.vect doesn't allow you _not_ to create the table...unless
you work with point data.
Moritz
