[GRASS-dev] r.univar: 'nan' results
Maciej Sieczka tutey at o2.pl
Thu Sep 14 19:13:47 EDT 2006
I've just noticed the r.univar.sh output is also screwed OK - the max
value is nan here! What the devil?!
> $ r.univar.sh cieki10_2zl_dir
> WARNING: This module is superseded and will be removed in future
> versions of GRASS. Use the much faster r.univar instead.
> Calculation for map cieki10_2zl_dir (ignoring NULL cells)...
> Reading raster map...
> r.stats:  100%
> Calculating statistics...
> Number of cells (excluding NULL cells): 4123
> Minimum: 0
> Maximum: nan
Maciek
