[GRASS-dev] Overlay grids and lines tool in gism fails to draw grid in map wi ndow
Fri Sep 15 01:44:26 EDT 2006
Maciej Sieczka wrote:
> >> d.grid segfaults for me too if I use RGB triplets for color or
> >> bordercolor. If I use names (blue, red etc.) it works.
> > Actually it works as long as the RGB values are 0 or 255. As soon as
> > they are something else it segfaults.
> Hmm, for me it segfaults whatever the values, eg.:
> $ d.grid size=2000 origin=0,0 bordercolor=1:1:1
> Segmentation fault
d.grid calls D_parse_color() before calling R_open_driver(), which
won't work unless the colour is one of the predefined colours
(D_parse_color() allocates the specified colour within the driver then
returns the index of the allocated colour).
