[GRASS-dev] making grass modules less verbose
Jachym Cepicky jachym.cepicky at centrum.cz
Wed Sep 20 04:04:54 EDT 2006
another idea: what about putting all grass messages (G_message,
G_warning, G_percent) to some GRASS_LOG
file, which would be grassdata/location/mapset/.grass.log by default?
The user could see, what's happening, regardless to how GRASS_VERBOSE is
set.
Jachym
On Wed, Sep 20, 2006 at 09:37:36AM +0200, Sören Gebbert wrote:
> Hi,
> i think this is a nice idea.
> Some modules are very verbose and with this approach a general
> way is provided to handle this verbosity.
> Best regards
> Soeren
> Jachym Cepicky schrieb:
> >Hallo,
> >following patch makes GRASS modules able to use --verbose flag or set
> >GRASS_VERBOSE environment variable.
> >In the code:
> >        if (module->verbose)
> >                    printf("Blah, blah, blah, blah\n");
> >or
> >                    G_percent(row, nrows, 2);
> >I thing, that according to Eric Steven Raymond, if the program does
> >not have anything interesting to say, it should say nothing. This is
> >good for embeding GRASS in some web server application or for some scripts.
> >But how to use it in old GRASS modules, so that the number of modules,
> >which must be corrected by hand, is as low as possible? Do you thing,
> >this is useful? Shall I put apply this to cvs?
> >Example session:
> >GRASS 6.3.cvs (spearfish60):~ > export GRASS_VERBOSE=0
> >GRASS 6.3.cvs (spearfish60):~ > r.example --help
> >Description:
> > My first raster module
> > Keywords:
> >  keyword1, keyword2, keyword3
> > Usage:
> >   r.example [-q] input=name output=name [--overwrite] [--verbose]
> > Flags:
> >    -q   Quiet
> >    --o   Force overwrite of output files
> >    --v   Verbose module output
> >Parameters:
> >    input   Name of input raster map
> >    output   Name for output raster map
> >GRASS 6.3.cvs (spearfish60):~ > r.example in=aspect out=aspect
> >GRASS 6.3.cvs (spearfish60):~ > r.example in=aspect out=aspect --v
> >93%
> >GRASS 6.3.cvs (spearfish60):~ > export GRASS_VERBOSE=1
> >93%
> >Looking forward to your comments
> >Jachym
> >Index: include/gis.h
> >RCS file: /home/grass/grassrepository/grass6/include/gis.h,v
> >retrieving revision 1.33
> >diff -u -r1.33 gis.h
> >--- include/gis.h	19 Aug 2006 12:52:21 -0000	1.33
> >+++ include/gis.h	19 Sep 2006 14:43:42 -0000
> >@@ -570,6 +570,7 @@
> >     char *keywords;                 /* Keywords describing module */
> > 	/* further items are possible: author(s), version */
> >     int overwrite; /* overwrite old files */
> >+    int verbose;   /* print all informations about progres and so on */
> > struct TimeStamp
> >Index: lib/gis/parser.c
> >RCS file: /home/grass/grassrepository/grass6/lib/gis/parser.c,v
> >retrieving revision 1.85
> >diff -u -r1.85 parser.c
> >--- lib/gis/parser.c	17 Sep 2006 21:50:00 -0000	1.85
> >+++ lib/gis/parser.c	19 Sep 2006 14:43:43 -0000
> >@@ -136,6 +136,7 @@
> > static int n_opts = 0 ;
> > static int n_flags = 0 ;
> > static int overwrite = 0 ;
> >+static int verbose = 0 ;
> > static struct Flag first_flag;    /* First flag in a linked list      */
> > static struct Flag *current_flag; /* Pointer for traversing list      */
> >@@ -171,6 +172,7 @@
> > static int split_opts();
> > static int check_multiple_opts();
> > static int check_overwrite();
> >+static int check_verbose();
> > static int interactive( char *);
> > static int interactive_flag( struct Flag *);
> > static int interactive_option( struct Option *);
> >@@ -728,6 +730,12 @@
> > 			    overwrite = 1;
> >+			/* Verbose option */
> >+                        else if ( strcmp(ptr,"--v") == 0 ||
> >strcmp(ptr,"--verbose") == 0 )
> >+			    module_info.verbose = 1;
> > 			/* Force gui to come up */
> > 			else if ( strcmp(ptr,"--ui") == 0 )
> >@@ -794,6 +802,9 @@
> > 	if ( check_overwrite () )
> > 	    return -1;
> >+	if (check_verbose ())
> > 	return(0) ;
> >@@ -932,6 +943,10 @@
> > 		len=show(item,len);
> >+        strcpy (item, " [--verbose]");
> >+        len=show(item,len);
> > 	fprintf (stderr, "\n");
> > 	/* Print help info for flags */
> >@@ -960,8 +975,9 @@
> > 	if (new_prompt)
> >-		fprintf(stderr," --o   %s\n", _("Force overwrite of output
> >files")) ;
> >+	        fprintf(stderr," --o   %s\n", _("Force overwrite of output
> >files")) ;
> >+        fprintf(stderr," --v   %s\n", _("Verbose module output")) ;
> > 	/* Print help info for options */
> >@@ -1334,9 +1350,10 @@
> > 	if (new_prompt)
> > 		fprintf(stdout, " [--<b>overwrite</b>] ");
> >+        fprintf(stdout, " [--<b>verbose</b>] ");
> > 	fprintf(stdout, "\n");
> >@@ -1371,6 +1388,10 @@
> > 			fprintf(stdout, "<DT><b>--overwrite</b></DT>\n");
> > 			fprintf(stdout, "<DD>Force overwrite of output
> > 			files</DD>");
> >+                fprintf(stdout, "<DT><b>--verbose</b></DT>\n");
> >+                fprintf(stdout, "<DD>Verbose module output</DD>");
> > 		fprintf(stdout, "</DL>\n");
> >@@ -2144,6 +2165,34 @@
> > 	return(error) ;
> >+/* Check verbose */
> >+static int check_verbose (void)
> >+	char *verstr;
> >+	int verb;
> >+	verb = 0;
> >+	/* Check the GRASS VERBOSE variable */
> >+	if ( (verstr = G__getenv ( "VERBOSE" )) ) {
> >+	    verb = atoi ( verstr );
> >+	/* Check the GRASS_OVERWRITE environment variable */
> >+	if ( (verstr = getenv ( "GRASS_VERBOSE" )) ) {
> >+	    if (atoi ( verstr ))
> >+		verb = 1;
> >+	if ( verb ) {
> >+	    /* Set the environment so that programs run in a script also
> >obey --o */
> >+	    putenv("GRASS_OVERWRITE=1");
> >+	    /* No need to check options for existing files if overwrite is
> >true */
> >+	return(verb) ;
> > static int interactive( char *command)
> >_______________________________________________
> >grass-dev mailing list
> >grass-dev at grass.itc.it
> >http://grass.itc.it/mailman/listinfo/grass-dev
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL:    http://gdf-hannover.de
Tel.:   +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060920/6eb1722b/attachment.bin
