[GRASS-dev] autoconf, LOC_CHECK_VERSION_INT
Radim Blazek radim.blazek at gmail.com
Wed Sep 20 13:03:44 EDT 2006
Hi.
I cannot create configure with autoconf 2.59, error:
configure.in:362: warning: AC_CANONICAL_HOST invoked multiple times
autoconf/specific.m4:363: AC_CYGWIN is expanded from...
configure.in:362: the top level
configure.in:44: error: possibly undefined macro: AC_MSG_ERROR
      If this token and others are legitimate, please use m4_pattern_allow.
      See the Autoconf documentation.
The reason I need to create configure is that macro
LOC_CHECK_VERSION_INT fails on crosscompiler,
patch is attached.
Radim
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060920/e6897b88/configure.in.obj
