[GRASS-dev] making grass modules less verbose
Wed Sep 20 16:38:44 EDT 2006
Jachym Cepicky wrote:
> > i think this is a nice idea.
> > Some modules are very verbose and with this approach a general
> > way is provided to handle this verbosity.
> I prepared new patch (for current cvs version) which makes all modules
> be able to use --verbose flag or to set GRASS_VERBOSE env. variable.
> G_message, G_warning and G_percent are now able to handle according to
> the user needs.
A few comments:
1. G_warning() should not be affected; warnings should be displayed
regardless of the verbosity setting.
2. I would provide a --quiet flag to allow verbosity to be disabled
for individual cases.
3. I wouldn't check for a GRASS variable with G__getenv(), as you
can't override that on a per-process basis.
