[GRASS-dev] Two kind questions...
Damiano Triglione damiano.triglione at polimi.it
Thu Sep 21 05:02:58 EDT 2006
----- Original Message -----
To: <rez at touchofmadness.com>
Cc: "Damiano Triglione" <damiano.triglione at polimi.it>;
<grass-dev at grass.itc.it>
Sent: Thursday, September 21, 2006 7:12 AM
Subject: Re: [GRASS-dev] Two kind questions...
> Brad Douglas wrote:
>> On Wed, 2006-09-20 at 20:44 +0200, Damiano Triglione wrote:
>>> 2. How can I list the (east,north) coordinate together with the
>>> attributes
>>> of a given vector points file? With v.out.ascii I can see coordinates
>>> and
>>> category; with db.select I can see category and decimal attributes; but
>>> how
>>> can I see all the information in a joint way?
> v.db.addcol to add columns x,y
> v.to.db to upload coordinates to x,y colums
> db.select to list cat with x,y attributes
> Is there a simpler way?
> Maciek
Thank you! Maybe a simpler way could be a grass module that performs the
actions above! Or a module that shows all the information without adding the
x,y columns (this would have the purpose to not increase the size of the
files stored in the hard disk with redundant information).
Damiano
