[GRASS-dev] i.atcorr "opts.foobar->answer" problem
Yann Chemin
ychemin at gmail.com
Sat Sep 23 08:18:49 EDT 2006
Hi list,
following previous trials for cleaning i.atcorr while adapting it to
CVS code, it looks that it now gets somewhere with the sample dataset
from Professor Wolfgang (it is processing the image right now). There
is one major frustration though, it seems the code does not read from
arguments given.
by defining: struct Options opts;
The "opts.input_file->answer" should point to a memory block that
contains the argument.
Unfortunately it does not hold anything. So far it seems to run when
defining "*->answer" with input arguments directly into the code (at
least it runs!).
Maybe because C++, maybe because some changes from GRASS5.x?
Could anybody give me a direction where to look for to get this fixed?
Thanks a lot,
Yann
Home:
http://maps.google.com/maps?q=37.936037,58.402939&hl=en&ie=UTF8&om=1&z=18&ll=37.93624,58.40332&spn=0.002018,0.004565&t=h&iwloc=A
Office:
http://maps.google.com/maps?q=37.941735,58.383912&hl=en&ie=UTF8&om=1&z=18&ll=37.941795,58.384084&spn=0.002018,0.004565&t=h&iwloc=A
