[GRASS-dev] [bug #5168] (grass) v.in.ogr: undefined symbol OGRRegisterAll
Maciek Sieczka via RT grass-bugs at intevation.de
Mon Sep 25 06:30:22 EDT 2006
Frank,
This bug might be OGR related.
guest wrote (Sun, Sep 24 2006 15:56:53):
> PC AMD-X86_64 Fc5 (Fedora-core-5)
> grass-6.3.cvs-x86_64-unknown-linux-gnu-23_09_2006.tar.gz
> download: grass.itc.it
> $ v.in.ogr dsn=adm.e00 output=adm1
> v.in.ogr: symbol lookup error: v.in.ogr: undefined symbol:
> OGRRegisterAll
> GRASS 6.3.cvs (d1144):/home/md/danguole/d1144/PERMANENT >
> EXP  0 /MULTID/DT13/UPDATE/EXP50LKS/1144/ADM.E00
> ARC  2
>          1         1         2         3         0         0         7
>  3.7567922E+05 6.1011955E+06 3.7574516E+05 6.1011565E+06
>  3.7582256E+05 6.1011005E+06 3.7593669E+05 6.1010175E+06
>  3.7603438E+05 6.1009595E+06 3.7613091E+05 6.1009115E+06
>  3.7617653E+05 6.1008895E+06
>          2         1         4         1         0         0         6
>  3.7988538E+05 6.1007795E+06 3.7996950E+05 6.1008715E+06
>  3.8004209E+05 6.1009545E+06 3.8012244E+05 6.1010585E+06
>  3.8017984E+05 6.1011625E+06 3.8020294E+05 6.1012205E+06
>          3         1         5         6         0         0         7
>  3.7704091E+05 6.1004985E+06 3.7716925E+05 6.1004755E+06
>  3.7728094E+05 6.1004505E+06 3.7738888E+05 6.1004305E+06
>  3.7748419E+05 6.1004115E+06 3.7756931E+05 6.1003985E+06
>  3.7762012E+05 6.1003945E+06
>         -1         0         0         0         0         0         0
> TOL  2
>          1         2 5.0010004E+00
>          2         2 0.0000000E+00
>          3         2 0.0000000E+00
>          4         2 0.0000000E+00
>          5         2 0.0000000E+00
>          6         2 2.5005000E+02
>          7         2 2.5005000E+01
>          8         2 2.5005000E+01
>          9         2 2.5005000E+01
>         10         2 2.5005000E+01
>         -1         0         0         0         0         0         0
> SIN  2
> EOX
> LOG  2
> 200012271231   0     0     0minde   export COVER 1144/adm ../exp50lks/1144/adm
> 200012271308   0     0     0minde   export COVER 1144/adm ../exp50lks/1144/adm
> EOL
> PRJ  2
> Projection    TRANSVERSE
> Zunits        NO
> Units         METERS
> Spheroid      GRS1980
> Xshift        0.0000000000
> Yshift        0.0000000000
> Parameters
> 0.99980 /* scale factor at central meridian
>  24  0  0.000 /* longitude of central meridian
>  0  0  0.000 /* latitude of origin
> 500000.00000 /* false easting (meters)
> 0.00000 /* false northing (meters)
> EOP
> IFO  2
> ADM.AAT                         XX   8   8  36         3
> FNODE#            4-1   14-1   5-1 50-1  -1  -1-1                   1-
> TNODE#            4-1   54-1   5-1 50-1  -1  -1-1                   2-
> LPOLY#            4-1   94-1   5-1 50-1  -1  -1-1                   3-
> RPOLY#            4-1  134-1   5-1 50-1  -1  -1-1                   4-
> LENGTH            4-1  174-1  12 3 60-1  -1  -1-1                   5-
> ADM#              4-1  214-1   5-1 50-1  -1  -1-1                   6-
> ADM-ID            4-1  254-1   5-1 50-1  -1  -1-1                   7-
> CODE              7-1  294-1   7-1 30-1  -1  -1-1                   8-
>           2          3          0          0 5.8524921E+02          1          1
>  110110
>           4          1          0          0 5.4753052E+02          2          1
>  110110
>           5          6          0          0 5.8876056E+02          3          1
>  110110
> ADM.BND                         XX   4   4  16         1
> XMIN              4-1   14-1  12 3 60-1  -1  -1-1                   1-
> YMIN              4-1   54-1  12 3 60-1  -1  -1-1                   2-
> XMAX              4-1   94-1  12 3 60-1  -1  -1-1                   3-
> YMAX              4-1  134-1  12 3 60-1  -1  -1-1                   4-
>  3.7497500E+05 6.0762155E+06 3.9998000E+05 6.1012205E+06
> ADM.TIC                         XX   3   3  12         4
> IDTIC             4-1   14-1   5-1 50-1  -1  -1-1                   1-
> XTIC              4-1   54-1  12 3 60-1  -1  -1-1                   2-
> YTIC              4-1   94-1  12 3 60-1  -1  -1-1                   3-
>           1 3.7497500E+05 6.1012205E+06
>           2 3.9998000E+05 6.1012205E+06
>           3 3.7497500E+05 6.0762155E+06
>           4 3.9998000E+05 6.0762155E+06
> EOI
> EOS
-------------------------------------------- Managed by Request Tracker
