[GRASS-dev] [bug #3729] (grass) g.region zoom= off by one error on eastern side
Mon Sep 25 13:38:02 EDT 2006
Maciek Sieczka via RT wrote:
> > Also, the issue is much worse than your example suggests. Because col
> > is one too high, the loop never examines the rightmost column.
> > Consider:
> > Thus, "g.region zoom=..." can actually make the region too small,
> > discarding valid data.
> Sorry for being slow - does your fix take care of that also?
