[GRASS-dev] Re: [GRASS-CVS] michael: grass6/lib/init epsg_option.tcl.in, 1.6, 1.7 file_option.tcl, 1.3, 1.4 gis_set.tcl, 1.33, 1.34
Huidae Cho grass4u at gmail.com
Mon Sep 25 15:25:34 EDT 2006
On Mon, Sep 25, 2006 at 12:14:13PM -0700, Michael Barton wrote:
> Which ones were affected by the windows patch?
epsg_option.tcl.in, gis_set.tcl: $devnull and $mingw if blocks.
Huidae
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: <grass4u at gmail.com>
> > Reply-To: <grass-dev at grass.itc.it>
> > Date: Mon, 25 Sep 2006 13:18:57 -0500
> > To: Michael Barton <michael.barton at asu.edu>
> > Subject: Re: [GRASS-CVS] michael: grass6/lib/init epsg_option.tcl.in, 1.6, 1.7
> > Hi,
> > You're reverting Windows patch.  Is there any reason for that?
> > PROJSHARE for the browsedepsg variable shouldn't be replaced with any
> > other values (e.g., Mac OS X default) since lib/init/Makefile and
> > lib/init/projshare.sed will substitute the string with an appropriate
> > value.
> > Thank you.
> > Huidae
> > Author: michael
> > Update of /grassrepository/grass6/lib/init
> > In directory doto:/tmp/cvs-serv3750
> > Modified Files:
> > epsg_option.tcl.in file_option.tcl gis_set.tcl
> > Log Message:
> > change so that default widget format (including fonts) controled
> > by option database (in options.tcl)
> > Index: epsg_option.tcl.in
> > RCS file: /grassrepository/grass6/lib/init/epsg_option.tcl.in,v
> > retrieving revision 1.6
> > retrieving revision 1.7
> > diff -u -d -r1.6 -r1.7
> > --- epsg_option.tcl.in 15 Sep 2006 10:22:42 -0000 1.6
> > +++ epsg_option.tcl.in 25 Sep 2006 17:55:12 -0000 1.7
> > @@ -59,11 +59,10 @@
> >          global thelocation
> >          global browsedepsg
> >          global locpath
> > - global mingw
> > # NOTE: the epsg file is generated in GDAL for PROJ4
> > # with gdal/pymod/epsg_tr.py
> > - set browsedepsg "PROJSHARE/epsg"
> > + set browsedepsg "/Library/Frameworks/PROJ.framework/Resources/proj/epsg"
> >          set epsgLocation "newLocation"
> >          set epsg_code ""
> >          set locpath $database
> > @@ -84,13 +83,13 @@
> >          #create the form and buttons
> >          label .optPopup.input1_ppb -text [G_msg "Name of new location"]
> > -justify right -height 2
> > -        entry .optPopup.input1_ppbEntry -textvariable epsgLocation -width 35
> > -bg white
> > +        entry .optPopup.input1_ppbEntry -textvariable epsgLocation -width 35
> >          label .optPopup.input2_ppb -text [G_msg "Path to new location"]
> > -        entry .optPopup.input2_ppbEntry -textvariable locpath  -width 35 -bg
> > white
> > +        entry .optPopup.input2_ppbEntry -textvariable locpath  -width 35
> >          label .optPopup.input3_ppb -text [G_msg "Path to the EPSG-codes
> > file"] -justify right -height 2
> > -        entry .optPopup.input3_ppbEntry -textvariable browsedepsg  -width 35
> > -bg white
> > +        entry .optPopup.input3_ppbEntry -textvariable browsedepsg  -width 35
> >          label .optPopup.input4_ppb -text [G_msg "EPSG code number of
> > projection"] -justify right -height 2
> > -        entry .optPopup.input4_ppbEntry -textvariable epsg_code  -width 35
> > -bg white
> > +        entry .optPopup.input4_ppbEntry -textvariable epsg_code  -width 35
> > #browse for database path
> >          button .optPopup.db -justify center -width 12 -text [G_msg
> > "Browse..."] \
> > @@ -108,7 +107,7 @@
> >          bind .optPopup.input3_ppbEntry <Leave> {
> >               if {$browsedepsg == ""} {
> > +                set browsedepsg
> > @@ -148,13 +147,8 @@
> > if {[file exists $browsedepsg]== 1} {
> > if {[file exists $thelocation ]==0} {
> > destroy .optPopup;
> > -      if { $mingw == "1" } {
> > -       exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e
> > $env(GISBASE)/etc/make_location_epsg.sh \
> > -        $epsg_code $epsgLocation $locpath;
> > -      } else {
> > -        $epsg_code $epsgLocation $locpath >@stdout 2>@stderr;
> > +      exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e
> > +       $epsg_code $epsgLocation $locpath >@stdout 2>@stderr;
> > DialogGen .wrnDlg [G_msg "WARNING: restart GRASS please"] warning \
> > [G_msg "WARNING: Please restart GRASS in order find the created location in
> > the list (closing it for you now)"] \
> > 0 OK;
> > @@ -301,7 +295,7 @@
> >          .infoPopup.text insert end [G_msg "\nThe folder (GRASS database) in
> > which the location should be created\n\n"] info
> >          .infoPopup.text insert end "\n"
> >          .infoPopup.text insert end [G_msg "\n   EPSG code number of
> > projection:\n\n"] subtitle
> > -        .infoPopup.text insert end [G_msg "\nEPSG code number of projection
> > (see PROJSHARE/epsg or push the 'EPSG-codes' button)\n\n"] info
> > +        .infoPopup.text insert end [G_msg "\nEPSG code number of projection
> > (see /Library/Frameworks/PROJ.framework/Resources/proj/epsg or push the
> >          pack .infoPopup.text -side left -fill both
> > Index: file_option.tcl
> > RCS file: /grassrepository/grass6/lib/init/file_option.tcl,v
> > retrieving revision 1.3
> > retrieving revision 1.4
> > diff -u -d -r1.3 -r1.4
> > --- file_option.tcl 14 Jun 2006 16:50:24 -0000 1.3
> > +++ file_option.tcl 25 Sep 2006 17:55:12 -0000 1.4
> > @@ -74,11 +74,11 @@
> > set loclab [label .fileloc.lab1 -text [G_msg "Name of new location"] -justify
> > right -height 2]
> > - set locname [entry .fileloc.loc -textvariable fileLocation -width 35 -bg
> > white]
> > + set locname [entry .fileloc.loc -textvariable fileLocation -width 35]
> > set dblab [label .fileloc.lab2 -text [G_msg "Path to new location"] -justify
> > right -height 2]
> > - set dbpath [entry .fileloc.locpath -textvariable locpath -width 35 -bg
> > white]
> > + set dbpath [entry .fileloc.locpath -textvariable locpath -width 35]
> > set filelab [label .fileloc.lab3 -text [G_msg "Path to georeferenced file"]
> > -justify right -height 2]
> > - set fpath [entry .fileloc.filepath -textvariable filepath  -width 35 -bg
> > white]
> > + set fpath [entry .fileloc.filepath -textvariable filepath  -width 35]
> > set dbbrowse [button .fileloc.dbbrow -justify center -width 12 \
> > Index: gis_set.tcl
> > RCS file: /grassrepository/grass6/lib/init/gis_set.tcl,v
> > retrieving revision 1.33
> > retrieving revision 1.34
> > diff -u -d -r1.33 -r1.34
> > --- gis_set.tcl 16 Sep 2006 01:56:24 -0000 1.33
> > +++ gis_set.tcl 25 Sep 2006 17:55:12 -0000 1.34
> > @@ -19,12 +19,6 @@
> > -if {[info exists env(MSYSCON)]} {
> > - set mingw "1"
> > -} else {
> > - set mingw "0"
> >  source $env(GISBASE)/etc/gtcltk/gmsg.tcl
> > @@ -32,6 +26,7 @@
> >  #   the EPSG codes    (routines epsgLocCom and infoEpsg)
> > +source $env(GISBASE)/etc/gtcltk/options.tcl
> >  source $env(GISBASE)/etc/epsg_option.tcl
> >  source $env(GISBASE)/etc/file_option.tcl
> > @@ -284,22 +279,18 @@
> >  proc gisSetWindow {} {
> >      global GRASSVERSION
> > -    # Window manager configurations
> > -    wm title . [format [G_msg "GRASS %s Startup"] $GRASSVERSION]
> >      global database
> >      global location
> >      global mymapset
> >      global mapset
> >      global oldDb oldLoc oldMap
> >      global env
> >      global grassrc_list
> >      global gisrc_name
> > -    global mingw
> > +    # Window manager configurations
> > +    wm title . [format [G_msg "GRASS %s Startup"] $GRASSVERSION]
> >      # build .frame0
> > @@ -313,8 +304,10 @@
> > "$env(GISBASE)/etc/gintro.gif"]]
> >      set introtitle [text $titlefrm.msg -height 5 \
> > -relief flat -fg darkgreen \
> > -     -font {Helvetica -14 bold} \
> > +     -bg #dddddd \
> > +     -font introfont \
> > -width 50 ]
> >      pack $titlefrm -side top
> > pack $introimg -side top
> >      pack $introtitle -side top
> > @@ -352,8 +345,7 @@
> > -relief {sunken} \
> > -textvariable database \
> > -width 40 \
> > -     -xscrollcommand { .frame0.frameDB.mid.hscrollbar set} \
> > -     -bg white
> > +     -xscrollcommand { .frame0.frameDB.mid.hscrollbar set}
> >      scrollbar .frame0.frameDB.mid.hscrollbar \
> > -command { .frame0.frameDB.mid.entry xview} \
> > @@ -361,31 +353,10 @@
> > -width 12 \
> > -orient {horizontal}
> > -       # We cannot use Double-Button-1 (change dir) and Button-1 (select dir)
> > -       # events at the same time because of MS-Windows TclTk's event bug.
> > -       button .frame0.frameDB.right.button \
> > -        -text [G_msg "Browse..."] \
> > -        -command {set database [tk_chooseDirectory -initialdir $database \
> > -     -parent .frame0 -title "New GIS data directory" -mustexist true]
> > -  cd $database
> > -  .frame0.frameLOC.listbox delete 0 end
> > -  .frame0.frameMS.listbox delete 0 end
> > -  foreach filename [lsort [glob -nocomplain *]] \
> > -   if {[file isdirectory $filename]} \
> > -    .frame0.frameLOC.listbox insert end $filename
> > -  .frame0.frameBUTTONS.ok configure -state disabled}
> > -    } else {
> > -        -command {GetDir .frame0.frameDB.mid.entry .frame0.frameLOC.listbox \
> > -            .frame0.frameMS.listbox}
> > +    button .frame0.frameDB.right.button \
> > +     -text [G_msg "Browse..."] \
> > +     -command {GetDir .frame0.frameDB.mid.entry .frame0.frameLOC.listbox \
> > +         .frame0.frameMS.listbox}
> >      pack .frame0.frameDB.left.label -side top
> > @@ -410,8 +381,7 @@
> > -relief {sunken} \
> > -exportselection false \
> > -yscrollcommand {.frame0.frameLOC.vscrollbar set} \
> > -     -xscrollcommand {.frame0.frameLOC.hscrollbar set} \
> > -     -bg white
> > +     -xscrollcommand {.frame0.frameLOC.hscrollbar set}
> >      scrollbar .frame0.frameLOC.vscrollbar -width 12 \
> > -command {.frame0.frameLOC.listbox yview} \
> > @@ -442,8 +412,7 @@
> >      listbox .frame0.frameMS.listbox \
> > -relief {sunken} \
> > -yscrollcommand {.frame0.frameMS.vscrollbar set} \
> > -     -xscrollcommand {.frame0.frameMS.hscrollbar set} \
> > -     -bg white
> > +     -xscrollcommand {.frame0.frameMS.hscrollbar set}
> >      scrollbar .frame0.frameMS.vscrollbar -width 12 \
> > -command {.frame0.frameMS.listbox yview} \
> > @@ -494,8 +463,7 @@
> >      entry .frame0.frameNMS.second.entry \
> > -relief {sunken} \
> > -textvariable mymapset \
> > -     -width 22 \
> > -     -bg white
> > +     -width 22
> >      button .frame0.frameNMS.third.button \
> > -text [G_msg "Create new mapset"] \
> > @@ -512,11 +480,11 @@
> >                  puts $varfp "DB_DRIVER: dbf"
> >                  puts $varfp "DB_DATABASE:
> > \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/"
> >                  close $varfp
> > -                catch {file attributes $mymapset/VAR -permissions u+rw,go+r}
> > +                file attributes $mymapset/VAR -permissions u+rw,go+r
> >                  file mkdir $mymapset/dbf
> >                  #copy over the WIND definition:
> > -  catch {file copy $mymapset/../PERMANENT/WIND $mymapset}
> > -                catch {file attributes $mymapset/WIND -permissions u+rw,go+r}
> > +                file copy $mymapset/../PERMANENT/WIND $mymapset
> > +                file attributes $mymapset/WIND -permissions u+rw,go+r
> >                  .frame0.frameMS.listbox insert end $mymapset
> >                  #TODO: select new MAPSET
> > @@ -668,7 +636,7 @@
> >      cd $database
> > -    foreach i [exec ls -a [pwd]] {
> > +    foreach i [exec ls -a [exec pwd]] {
> > if { [string compare $i "."] != 0 && \
> >              [string compare $i ".."] != 0 && \
> >              [file isdirectory $i] } {
> > @@ -694,7 +662,7 @@
> >      if { [file exists $location] } \
> > cd $location
> > [file isdirectory $i] && [file owned $i] } {
> > @@ -726,7 +694,7 @@
> >             %W insert 0 $new_path
> >             cd $new_path
> > @@ -734,7 +702,7 @@
> > -           set database [pwd]
> > +           set database [exec pwd]
> > @@ -745,7 +713,7 @@
> >          set location [%W get [%W nearest %y]]
> >          cd $location
> > @@ -762,7 +730,7 @@
> >          cd $location
> > grass-commit mailing list
> > grass-commit at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-commit
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
