[GRASS-dev] Re: [GRASS-CVS] michael: grass6/lib/init epsg_option.tcl.in, 1.6, 1.7 file_option.tcl, 1.3, 1.4 gis_set.tcl, 1.33, 1.34
Michael Barton michael.barton at asu.edu
Mon Sep 25 16:39:43 EDT 2006
I believe I've reverted the windows changes that I accidentally overwrote
this morning and merged in the new changes to make internationalization
easier.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Huidae Cho <grass4u at gmail.com>
> Date: Mon, 25 Sep 2006 14:25:34 -0500
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] Re: [GRASS-CVS] michael: grass6/lib/init
> On Mon, Sep 25, 2006 at 12:14:13PM -0700, Michael Barton wrote:
>> Which ones were affected by the windows patch?
> epsg_option.tcl.in, gis_set.tcl: $devnull and $mingw if blocks.
> Huidae
>> Michael
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> From: <grass4u at gmail.com>
>>> Reply-To: <grass-dev at grass.itc.it>
>>> Date: Mon, 25 Sep 2006 13:18:57 -0500
>>> Subject: Re: [GRASS-CVS] michael: grass6/lib/init epsg_option.tcl.in, 1.6,
>>> 1.7
>>> Hi,
>>> You're reverting Windows patch.  Is there any reason for that?
>>> PROJSHARE for the browsedepsg variable shouldn't be replaced with any
>>> other values (e.g., Mac OS X default) since lib/init/Makefile and
>>> lib/init/projshare.sed will substitute the string with an appropriate
>>> value.
>>> Thank you.
>>> Huidae
>>> Author: michael
>>> Update of /grassrepository/grass6/lib/init
>>> In directory doto:/tmp/cvs-serv3750
>>> Modified Files:
>>> epsg_option.tcl.in file_option.tcl gis_set.tcl
>>> Log Message:
>>> change so that default widget format (including fonts) controled
>>> by option database (in options.tcl)
>>> Index: epsg_option.tcl.in
>>> RCS file: /grassrepository/grass6/lib/init/epsg_option.tcl.in,v
>>> retrieving revision 1.6
>>> retrieving revision 1.7
>>> diff -u -d -r1.6 -r1.7
>>> --- epsg_option.tcl.in 15 Sep 2006 10:22:42 -0000 1.6
>>> +++ epsg_option.tcl.in 25 Sep 2006 17:55:12 -0000 1.7
>>> @@ -59,11 +59,10 @@
>>>          global thelocation
>>>          global browsedepsg
>>>          global locpath
>>> - global mingw
>>> # NOTE: the epsg file is generated in GDAL for PROJ4
>>> # with gdal/pymod/epsg_tr.py
>>> - set browsedepsg "PROJSHARE/epsg"
>>> + set browsedepsg "/Library/Frameworks/PROJ.framework/Resources/proj/epsg"
>>>          set epsgLocation "newLocation"
>>>          set epsg_code ""
>>>          set locpath $database
>>> @@ -84,13 +83,13 @@
>>>          #create the form and buttons
>>>          label .optPopup.input1_ppb -text [G_msg "Name of new location"]
>>> -justify right -height 2
>>> -        entry .optPopup.input1_ppbEntry -textvariable epsgLocation -width
>>> 35
>>> -bg white
>>> +        entry .optPopup.input1_ppbEntry -textvariable epsgLocation -width
>>> 35
>>>          label .optPopup.input2_ppb -text [G_msg "Path to new location"]
>>> -        entry .optPopup.input2_ppbEntry -textvariable locpath  -width 35
>>> -bg
>>> white
>>> +        entry .optPopup.input2_ppbEntry -textvariable locpath  -width 35
>>>          label .optPopup.input3_ppb -text [G_msg "Path to the EPSG-codes
>>> file"] -justify right -height 2
>>> -        entry .optPopup.input3_ppbEntry -textvariable browsedepsg  -width
>>> 35
>>> -bg white
>>> +        entry .optPopup.input3_ppbEntry -textvariable browsedepsg  -width
>>> 35
>>>          label .optPopup.input4_ppb -text [G_msg "EPSG code number of
>>> projection"] -justify right -height 2
>>> -        entry .optPopup.input4_ppbEntry -textvariable epsg_code  -width 35
>>> -bg white
>>> +        entry .optPopup.input4_ppbEntry -textvariable epsg_code  -width 35
>>> #browse for database path
>>>          button .optPopup.db -justify center -width 12 -text [G_msg
>>> "Browse..."] \
>>> @@ -108,7 +107,7 @@
>>>          bind .optPopup.input3_ppbEntry <Leave> {
>>>               if {$browsedepsg == ""} {
>>> +                set browsedepsg
>>> @@ -148,13 +147,8 @@
>>> if {[file exists $browsedepsg]== 1} {
>>> if {[file exists $thelocation ]==0} {
>>> destroy .optPopup;
>>> -      if { $mingw == "1" } {
>>> -       exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e
>>> $env(GISBASE)/etc/make_location_epsg.sh \
>>> -        $epsg_code $epsgLocation $locpath;
>>> -      } else {
>>> -        $epsg_code $epsgLocation $locpath >@stdout 2>@stderr;
>>> +      exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e
>>> +       $epsg_code $epsgLocation $locpath >@stdout 2>@stderr;
>>> DialogGen .wrnDlg [G_msg "WARNING: restart GRASS please"] warning \
>>> [G_msg "WARNING: Please restart GRASS in order find the created location in
>>> the list (closing it for you now)"] \
>>> 0 OK;
>>> @@ -301,7 +295,7 @@
>>>          .infoPopup.text insert end [G_msg "\nThe folder (GRASS database) in
>>> which the location should be created\n\n"] info
>>>          .infoPopup.text insert end "\n"
>>>          .infoPopup.text insert end [G_msg "\n   EPSG code number of
>>> projection:\n\n"] subtitle
>>> -        .infoPopup.text insert end [G_msg "\nEPSG code number of projection
>>> (see PROJSHARE/epsg or push the 'EPSG-codes' button)\n\n"] info
>>> +        .infoPopup.text insert end [G_msg "\nEPSG code number of projection
>>> (see /Library/Frameworks/PROJ.framework/Resources/proj/epsg or push the
>>>          pack .infoPopup.text -side left -fill both
>>> Index: file_option.tcl
>>> RCS file: /grassrepository/grass6/lib/init/file_option.tcl,v
>>> retrieving revision 1.3
>>> retrieving revision 1.4
>>> diff -u -d -r1.3 -r1.4
>>> --- file_option.tcl 14 Jun 2006 16:50:24 -0000 1.3
>>> +++ file_option.tcl 25 Sep 2006 17:55:12 -0000 1.4
>>> @@ -74,11 +74,11 @@
>>> set loclab [label .fileloc.lab1 -text [G_msg "Name of new location"]
>>> -justify
>>> right -height 2]
>>> - set locname [entry .fileloc.loc -textvariable fileLocation -width 35 -bg
>>> white]
>>> + set locname [entry .fileloc.loc -textvariable fileLocation -width 35]
>>> set dblab [label .fileloc.lab2 -text [G_msg "Path to new location"] -justify
>>> right -height 2]
>>> - set dbpath [entry .fileloc.locpath -textvariable locpath -width 35 -bg
>>> white]
>>> + set dbpath [entry .fileloc.locpath -textvariable locpath -width 35]
>>> set filelab [label .fileloc.lab3 -text [G_msg "Path to georeferenced file"]
>>> -justify right -height 2]
>>> - set fpath [entry .fileloc.filepath -textvariable filepath  -width 35 -bg
>>> white]
>>> + set fpath [entry .fileloc.filepath -textvariable filepath  -width 35]
>>> set dbbrowse [button .fileloc.dbbrow -justify center -width 12 \
>>> Index: gis_set.tcl
>>> RCS file: /grassrepository/grass6/lib/init/gis_set.tcl,v
>>> retrieving revision 1.33
>>> retrieving revision 1.34
>>> diff -u -d -r1.33 -r1.34
>>> --- gis_set.tcl 16 Sep 2006 01:56:24 -0000 1.33
>>> +++ gis_set.tcl 25 Sep 2006 17:55:12 -0000 1.34
>>> @@ -19,12 +19,6 @@
>>> -if {[info exists env(MSYSCON)]} {
>>> - set mingw "1"
>>> -} else {
>>> - set mingw "0"
>>>  source $env(GISBASE)/etc/gtcltk/gmsg.tcl
>>> @@ -32,6 +26,7 @@
>>>  #   the EPSG codes    (routines epsgLocCom and infoEpsg)
>>> +source $env(GISBASE)/etc/gtcltk/options.tcl
>>>  source $env(GISBASE)/etc/epsg_option.tcl
>>>  source $env(GISBASE)/etc/file_option.tcl
>>> @@ -284,22 +279,18 @@
>>>  proc gisSetWindow {} {
>>>      global GRASSVERSION
>>> -    # Window manager configurations
>>> -    wm title . [format [G_msg "GRASS %s Startup"] $GRASSVERSION]
>>>      global database
>>>      global location
>>>      global mymapset
>>>      global mapset
>>>      global oldDb oldLoc oldMap
>>>      global env
>>>      global grassrc_list
>>>      global gisrc_name
>>> -    global mingw
>>> +    # Window manager configurations
>>> +    wm title . [format [G_msg "GRASS %s Startup"] $GRASSVERSION]
>>>      # build .frame0
>>> @@ -313,8 +304,10 @@
>>> "$env(GISBASE)/etc/gintro.gif"]]
>>>      set introtitle [text $titlefrm.msg -height 5 \
>>> -relief flat -fg darkgreen \
>>> -     -font {Helvetica -14 bold} \
>>> +     -bg #dddddd \
>>> +     -font introfont \
>>> -width 50 ]
>>>      pack $titlefrm -side top
>>> pack $introimg -side top
>>>      pack $introtitle -side top
>>> @@ -352,8 +345,7 @@
>>> -relief {sunken} \
>>> -textvariable database \
>>> -width 40 \
>>> -     -xscrollcommand { .frame0.frameDB.mid.hscrollbar set} \
>>> -     -bg white
>>> +     -xscrollcommand { .frame0.frameDB.mid.hscrollbar set}
>>>      scrollbar .frame0.frameDB.mid.hscrollbar \
>>> -command { .frame0.frameDB.mid.entry xview} \
>>> @@ -361,31 +353,10 @@
>>> -width 12 \
>>> -orient {horizontal}
>>> -       # We cannot use Double-Button-1 (change dir) and Button-1 (select
>>> dir)
>>> -       # events at the same time because of MS-Windows TclTk's event bug.
>>> -       button .frame0.frameDB.right.button \
>>> -        -text [G_msg "Browse..."] \
>>> -        -command {set database [tk_chooseDirectory -initialdir $database \
>>> -     -parent .frame0 -title "New GIS data directory" -mustexist true]
>>> -  cd $database
>>> -  .frame0.frameLOC.listbox delete 0 end
>>> -  .frame0.frameMS.listbox delete 0 end
>>> -  foreach filename [lsort [glob -nocomplain *]] \
>>> -   if {[file isdirectory $filename]} \
>>> -    .frame0.frameLOC.listbox insert end $filename
>>> -  .frame0.frameBUTTONS.ok configure -state disabled}
>>> -    } else {
>>> -        -command {GetDir .frame0.frameDB.mid.entry .frame0.frameLOC.listbox
>>> -            .frame0.frameMS.listbox}
>>> +    button .frame0.frameDB.right.button \
>>> +     -text [G_msg "Browse..."] \
>>> +     -command {GetDir .frame0.frameDB.mid.entry .frame0.frameLOC.listbox \
>>> +         .frame0.frameMS.listbox}
>>>      pack .frame0.frameDB.left.label -side top
>>> @@ -410,8 +381,7 @@
>>> -relief {sunken} \
>>> -exportselection false \
>>> -yscrollcommand {.frame0.frameLOC.vscrollbar set} \
>>> -     -xscrollcommand {.frame0.frameLOC.hscrollbar set} \
>>> -     -bg white
>>> +     -xscrollcommand {.frame0.frameLOC.hscrollbar set}
>>>      scrollbar .frame0.frameLOC.vscrollbar -width 12 \
>>> -command {.frame0.frameLOC.listbox yview} \
>>> @@ -442,8 +412,7 @@
>>>      listbox .frame0.frameMS.listbox \
>>> -relief {sunken} \
>>> -yscrollcommand {.frame0.frameMS.vscrollbar set} \
>>> -     -xscrollcommand {.frame0.frameMS.hscrollbar set} \
>>> -     -bg white
>>> +     -xscrollcommand {.frame0.frameMS.hscrollbar set}
>>>      scrollbar .frame0.frameMS.vscrollbar -width 12 \
>>> -command {.frame0.frameMS.listbox yview} \
>>> @@ -494,8 +463,7 @@
>>>      entry .frame0.frameNMS.second.entry \
>>> -relief {sunken} \
>>> -textvariable mymapset \
>>> -     -width 22 \
>>> -     -bg white
>>> +     -width 22
>>>      button .frame0.frameNMS.third.button \
>>> -text [G_msg "Create new mapset"] \
>>> @@ -512,11 +480,11 @@
>>>                  puts $varfp "DB_DRIVER: dbf"
>>>                  puts $varfp "DB_DATABASE:
>>> \$GISDBASE/\$LOCATION_NAME/\$MAPSET/dbf/"
>>>                  close $varfp
>>> -                catch {file attributes $mymapset/VAR -permissions
>>> u+rw,go+r}
>>> +                file attributes $mymapset/VAR -permissions u+rw,go+r
>>>                  file mkdir $mymapset/dbf
>>>                  #copy over the WIND definition:
>>> -  catch {file copy $mymapset/../PERMANENT/WIND $mymapset}
>>> -                catch {file attributes $mymapset/WIND -permissions
>>> u+rw,go+r}
>>> +                file copy $mymapset/../PERMANENT/WIND $mymapset
>>> +                file attributes $mymapset/WIND -permissions u+rw,go+r
>>>                  .frame0.frameMS.listbox insert end $mymapset
>>>                  #TODO: select new MAPSET
>>> @@ -668,7 +636,7 @@
>>>      cd $database
>>> -    foreach i [exec ls -a [pwd]] {
>>> +    foreach i [exec ls -a [exec pwd]] {
>>> if { [string compare $i "."] != 0 && \
>>>              [string compare $i ".."] != 0 && \
>>>              [file isdirectory $i] } {
>>> @@ -694,7 +662,7 @@
>>>      if { [file exists $location] } \
>>> cd $location
>>> [file isdirectory $i] && [file owned $i] } {
>>> @@ -726,7 +694,7 @@
>>>             %W insert 0 $new_path
>>>             cd $new_path
>>> @@ -734,7 +702,7 @@
>>> -           set database [pwd]
>>> +           set database [exec pwd]
>>> @@ -745,7 +713,7 @@
>>>          set location [%W get [%W nearest %y]]
>>>          cd $location
>>> @@ -762,7 +730,7 @@
>>>          cd $location
>>> grass-commit mailing list
>>> grass-commit at grass.itc.it
>>> http://grass.itc.it/mailman/listinfo/grass-commit
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
