[GRASS-dev] Re: [GRASS-user] Solaris 10
    Glynn Clements
    glynn at gclements.plus.com
    Wed Sep 27 17:04:20 EDT 2006
[CC'd to grass-dev for reference.]
Bencze Sándor wrote:
> >> I try to compile GRASS to "Solaris 10 6/06" and I can't! I have tryed
> >> with gcc <> Solaris cc, make , gmake, dmake and I got allways errors.
> >> The last one is this:
> >> Errors in:
> >> /home/elv/Documents/Downloads/Grass/grass-6.1.0/lib/vask
> > This is probably a curses issue. Check the output from "make" for the
> > actual error message.
> Yes, this is a curses problem with the following error message:
> gcc -shared -o
> /home/elv/Documents/Downloads/Grass/grass-6.1.0/dist.sparc-sun-solaris2.10/lib/libgrass_vask.6.1.0.so
> -L/home/elv/Documents/Downloads/Grass/grass-6.1.0/dist.sparc-sun-solaris2.10/lib
> -L/usr/lib -L/usr/local/lib -L/usr/sfw/lib -L/usr/lib/64
> -Wl,-R,/home/elv/Documents/Downloads/Grass/grass-6.1.0/dist.sparc-sun-solaris2.10/lib
> OBJ.sparc-sun-solaris2.10/V_acc.o OBJ.sparc-sun-solaris2.10/V_call.o
> OBJ.sparc-sun-solaris2.10/V_clear.o OBJ.sparc-sun-solaris2.10/V_const.o
> OBJ.sparc-sun-solaris2.10/V_error.o OBJ.sparc-sun-solaris2.10/V_exit.o
> OBJ.sparc-sun-solaris2.10/V_init.o OBJ.sparc-sun-solaris2.10/V_line.o
> OBJ.sparc-sun-solaris2.10/V_ques.o OBJ.sparc-sun-solaris2.10/V_support.o
> OBJ.sparc-sun-solaris2.10/V_trim_dec.o -lncurses  && if [ -z "" ] ; then
> ln -f -s libgrass_vask.6.1.0.so
> /home/elv/Documents/Downloads/Grass/grass-6.1.0/dist.sparc-sun-solaris2.10/lib/libgrass_vask.so;
> fi
> Text relocation remains                     referenced
>     against symbol            offset    in file
> <unknown>                           0x670
> /usr/local/lib/libncurses.a(lib_addch.o)
> ld: fatal: relocations remain against allocatable but non-writable sections
> collect2: ld returned 1 exit status
> gmake: ***
> [/home/elv/Documents/Downloads/Grass/grass-6.1.0/dist.sparc-sun-solaris2.10/lib/libgrass_vask.6.1.0.so]
> Error 1
> But I have a brand new curses compilend in the default location!
Several options:
1. Recompile the curses library either as a shared library or with
-fPIC, so that shared libraries can be linked against it.
2. Remove the line:
	EXTRA_LIBS=$(CURSES)
from lib/vask/Makefile, and change the line:
	VASKLIB       = -l$(VASK_LIBNAME)
to:
	VASKLIB       = -l$(VASK_LIBNAME) $(CURSES)
in include/Make/Grass.make and/or include/Make/Grass.make.in.
3. If Solaris provides a shared [n]curses library in /usr/lib, create
a symlink named libncurses.so in e.g. /usr/local/lib.
The configure script prefers -lncurses to -lcurses, so if you have a
shared libcurses and a static libncurses, it will chose the latter,
even though the former is preferable. OTOH, if you have both shared
and static versions with the same name in the same directory, the
shared version will normally be preferred.
