[GRASS-dev] return of the OSX xterm question
William Kyngesburye woklist at kyngchaos.com
Sun Apr 15 14:57:15 EDT 2007
I worked out how to dump the env into a script to be sourced in the
Terminal window, as suggested by Glynn.  This removes the lengthy
output before the command is actually run (though the source command
is still there).  And it makes the AppleScript a little simpler.
As before, replace the installed grass /etc/grass-xterm-wrapper with
this one (or replace the source /lib/init/grass-xterm-wrapper and
rebuild).  Also, update CVS for the latest OSX app startup (and
rebuild) - I removed the hardwired xterm path.
Skipped content of type multipart/appledouble-------------- next part --------------
If this works well, I'll commit it to CVS.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
