[GRASS-dev] impressions on wx GUI
Michael Barton michael.barton at asu.edu
Sun Apr 15 21:26:04 EDT 2007
The overlay flag has nothing to do with transparency. What may be happening
is that the rendering algorithm is not catching the transparency change
until you change some other option for the layer. I don't get that behavior,
so I kind of guessing, however.
Michael
On 4/14/07 9:58 AM, "Carlos "Guâno" Grohmann" <carlos.grohmann at gmail.com>
wrote:
> Just tested it. Multiple selection of map layers is working fine.
> I had some problems with the transparency. The first time I set a
> transparency value, I did not worked. Then I set the overlay flag on,
> and it worked. then I changed the transparency value and it didn't
> worked again. when I unset the overlay, it worked...
> Carlos
> On 4/14/07, Michael Barton <michael.barton at asu.edu> wrote:
>> Done for layer delete AND for querying multiple raster/vector maps
>> simultaneously
>> Michael
>> On 4/12/07 5:20 PM, "Michael Barton" <michael.barton at asu.edu> wrote:
>>>> Multiple selection of layers in GIS Manager. If you want to delete
>>>> several layers, it is a pain to do it one by one.
>>> Duly noted. Multiple drag and drop is more difficult however.
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
