[GRASS-dev] nviz crashes on MacOSX
Agustin Diez Castillo Agustin.Diez at uv.es
Thu Apr 19 13:47:38 EDT 2007
I did compile with TCLTKPREFIX=/usr/local/tcltk. At first it refuses
to launch grass, if the terminal was already open nothing happened
otherwise I got this:
GRASS 6.3.cvs (Projecte):/Applications/GRASS-6.3.app/Contents/
Resources > gis.m &
Resources > Xlib: connection to ":0.0" refused by server
Xlib: No protocol specified
Application initialization failed: couldn't connect to display ":0.0"
Error in startup script: couldn't connect to display ":0.0"
     while executing
"load /Applications/GRASS-6.3.app/Contents/Resources/lib/tk8.4/../
libtk8.4.dylib Tk"
     ("package ifneeded" script)
     invoked from within
"package require Tk 8.0"
     invoked from within
"package require -exact BWidget 1.2.1"
     (file "/Applications/GRASS-6.3.app/Contents/Resources/etc/gm/
gm.tcl" line 24)
After fixing .grassrc GRASS_GUI=tcltk (as expected it changes to text
after failure) it starts either the aqua tclktk or the x11 one
(arbitrarily as far as I can say); after several tryouts I got what I
want grass started from x11 but nviz still crashes, I have tried from
both the icon and the terminal. Now everything I try but nviz is working
On Apr 19, 2007, at 5:15 PM, William Kyngesburye wrote:
> Looks like for some reason it's using the system TclTk instead of
> the one bundled in the GRASS app package.
> Make sure your X11 build of TclTk got bundled in the app package.
> It's possible the automatic detection of the TclTk prefix isn't
> working for the bundling stage, like we discussed offlist, and you
> would have to set TCLTKPREFIX before building GRASS.  If you used
> the universal tcltk build instructions in the readme, then that
> would be /usr/local/tcltk.
> On Apr 19, 2007, at 8:24 AM, Agustin Diez Castillo wrote:
>> After compiling and installing latest cvs following William's
>> readme, I got this error when trying nviz (itt works fine when
>> using his binaries):
>> Date/Time:      2007-04-19 13:10:33.116 +0200
>> OS Version:     10.4.9 (Build 8P2137)
>> Report Version: 4
>> Command: nviz
>> Path:    /Applications/GRASS-6.3.app/Contents/Resources/etc/
>> nviz2.2/nviz
>> Parent:  wish8.4 [15392]
>> Version: ??? (???)
>> PID:    15397
>> Thread: 0
>> Exception:  EXC_BAD_ACCESS (0x0001)
>> Codes:      KERN_INVALID_ADDRESS (0x0001) at 0x6e614320
>> Thread 0 Crashed:
>> 0   libX11.6.dylib       	0x005dacd2 XQueryExtension + 51
>> 0x9ac47000 - 0x9acc5fff com.tcltk.tcllibrary 8.4.7 a	/System/
>> Library/Frameworks/Tcl.framework/Versions/8.4/Tcl
>> 0x9acdf000 - 0x9ad8efff com.tcltk.tklibrary 8.4.7 a	/System/
>> Library/Frameworks/Tk.framework/Versions/8.4/Tk
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Oh, look, I seem to have fallen down a deep, dark hole.  Now what
> does that remind me of?  Ah, yes - life."
> - Marvin
Skipped content of type multipart/related
